Question about Nintendo DSi Blue Console
My Dsi was working fine , and then it just went out! What fuse should I try to repair? Where do I get replacement fuses? And how would I fix it?
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
Unfortunately, there are no fuses in the Nintendo DSi to replace, nor any simple way to fix it. First make sure that its not that your battery is simply dead. If that is not the problem, check to see if you have a valid warranty and call Nintendo about getting a replacement. Information on doing this can be found here (http://www.nintendo.com/consumer/systems/dsi/en_na/trouble.jsp)
Posted on Mar 21, 2011
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Starter Fuse Keeps Blowing When I Try To Start My 2001 Camry
The starter has gone to ground. This is either a coincidence of age or the repair shop left something disconnected that has slapped around and grounded the starter or some of their other work has shifted around and done it. It could just be a coincidence. If it went to ground internally, it will need replacing. If something shifted and grounded it out, putting that something where it belongs and THEN replacing a fuse should fix it. Most shops reuse your starter on their new engine.
Apr 16, 2017 | Toyota Camry Cars & Trucks
My dsi will not come on
IF it been drop. you need to take it apart and resolder the fuse back in. becare when you open it you can lose the fuse. does the DSI ligth come on went adapter is hook to it
Aug 08, 2011 | Nintendo DSi Black Console
Hmy dsi won't turn on
many people encountered this problem but it seems that the only solution is to open it and replace the FUSE or if you don't have money, Solder the place where the fuse goes in together.
This is the fuse location if you prefer to fix it by your self
http://www.tygarbyte.com/images/NDSi/NDSi%20Fuse/NDSiF1_Fuse_Main.jpg
I've fixed one before. It is so easy to do as long as you don't mess with any other thing there
Apr 12, 2011 | Nintendo DSi Blue Console
Picture went black but you could still hear the movie
Hi- My PL4260N stopped working after about three years, the audio worked but no video at all. The TV worked fine until one day...no more picture.
I found out that the YSUS and ZSUS boards in the TC fail alot...BUT you can get new or repaired ones off of EBAY...
First check for failed components (burned, loose, bulging, etc.) if nothing obvious is failed then check the fuses on the YSUS, ZSUS, and power supply boards...usually if a board has a blown fuse the board needs to be replaced...get the part number and search it in Google and eBay and you will find options for replace/repair.
Mine had a blown fuse on the YSUS board...I got it fixed for $75 through coppell TV (they are on Ebay)....
Now my TV works fine again!
Good luck.
Dec 19, 2010 | HP PL4260N 42 in. Plasma HDTV
If i press power on the blue led flashed and the dsi doesnot be swich on and the led is light out
Sounds to me like a blown fuse. I fixed the same problem on mine by replacing one. You can tell if a fuse is broken if there is no continuity across it. There are tutorials online, but the fuses are smaller then the letters in this sentence, so soldering them on takes some skill. It also involves opening your system and voiding any warranty you may have.
Also note that the linked tutorial is not for the dsi specifically. There is one fuse in a different location on the dsi then on the ds lite. If you choose to attempt this repair, I can walk you through it.
Mar 03, 2010 | Nintendo DSi White Console
Turn Signals and Highbeams don't work
I just had this happen to me. The computer flashed "ABS system failure" and my steering wheel controls went out, and the wipers, and turn signals/high beams. The really weird thing is that some of the dash went out (i.e. the temperature went out, but the clock didn't).
I figured this was a computer problem, so I just pulled the fuses (the ones under the hood) and put them back in. The computer still flashes "ABS System Failure" but the car runs perfect.
Jul 15, 2008 | 2000 Volvo S80
Lost power suddenly
Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
http://www.partselect.com/microwave+replace-fuse+repair.htm
Jan 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Nintendo DSi Blue Console Logo
170 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
