Question about Nintendo Wii Console
Hi, I just bought a Wii with supermario edition (color red). I have set-up the wireless internet already when it asked if I want to update the sytem's version. When I tried to use the sytem update, an error 3207 appeared. Need help to update my Wii system so I can use the channels. Thanks
  • Ed
    Ed Mar 21, 2011
    Did you mean error code 32007?
    Novelist:
  • 102 Answers
Basically you lost internet connection in the middle of the System Update. If you can regain an internet connection I would suggest just trying again until it finishes. If you plan on playing online, or if you can't get it to finish updating, you'll probably need to fix your internet connection problem.
Nintendo has an excellent online knowledge base for this, which outlines a number of fixes. Your specific problem is found here.
Changing your router's channel really can work wonders, which is also described on the Nintendo website.
Posted on Mar 21, 2011
To connect two wii consoles
Hi arbazfar,
First off, you will need a Wi-Fi connection to hook-up your consoles.
- Select the Wii logo (lower-left corner of the main menu)
- Select "WII SETTINGS" , then "INTERNET OPTIONS" option , then "CONNECTION SETTINGS".
- Select one of the available selections and confirm the "WIRELESS CONNECTION" option.
- Select the "SEARCH FOR ACCESS POINT" ( the Wii console will now look for the best local Wi-Fi connections available).
- Pick your preferred access point and then save your settings (Wii will then test the connection and may ask you to perform an update - just press "YES")
-Go to the "ADDRESS BOOK" (from the Wii main menu under the Wii Message Board). You should see a Friend Code on Page 1. Share your code with a friend you wish to connect to.
-Once you already have the code, press "REGISTER" in the Address Book, select the WII OPTION and enter the Friend code.
For more readings regaring this matter, you may go to the attached link: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
All the best to you. Hope to hear positive results.
Jul 08, 2011 | Nintendo Wii Console
Tip
How to access wireless internet in WII ?
First of all you need to know what is the Network name (SSID) and Password(security key) for your wireless network... Also make sure the firewall is disabled in your wireless router....Now, turn on the Wii...
Click the icon that looks like a house (home) on the Wii remote, you will see the Menu of your WII console...
Go to the settings > Select Internet connection settings > Select Wireless > Now select look for an Access Point in range...
You will see the list of available networks in range.... You must be able to see your network name among the list of wireless networks... Now select your network and select done...
Now it will ask you to enter the security settings... Enter your WPA or WEP key and select done...!
Thats it ! You are done...! Now it will test the Internet connection... After testing the connection, it will ask you to update the firmware, update the firmware and finish the process... You must be able to play the games online...
on Dec 20, 2010 | Nintendo Wii Console
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
How do conect the wii to the internet?
Are you trying to connect by using a wired connection or a wireless connection?
For wireless:
  1. Click the Wii at the bottom left side of your screen.
  2. Click Wii Settings
  3. Click the arrow on the right side of your screen.
  4. Choose Internet.
  5. Choose Connection Settings.
  6. Choose Connection 1 to create a new connection.
  7. Choose Wireless Connection.
  8. Choose Search for an Access Point
  9. Click OK then choose the correct access point (where you connect to the Internet)
  10. Click OK to save the settings.
  11. After the test, if asked to perform a Wii System Update, choose Yes.
For wired: You need to purchase a Wii LAN adapter. Then the step are the same as above except step 7 you pick wired connection instead of wireless.
Comment if you have any questions.
Apr 07, 2011 | Computers & Internet
How do you connect the wii to the internet?
Ok. If you have internet at your home already then, what you need to do is go to the main menu where it shows all the "channels" you have. At the bottom left will be the wii options menu click it, go to wii settings, click the right arrow once click internet, click connection settings. Pick which connection you want it doesnt matter which one you pick. So click one and if you have wireless internet click wireless and click search for an access point and your internet connection from your house should show up if not that is something wrong with the router not the wii at all. Save the settings and click ok for connection test if asks for a wii update hit no and then when it takes you back click at the top use this connection and you will be good to go with the connection
Hope I Helped and Explained without issues NoobTerminator aka Manchild
Mar 26, 2011 | Nintendo Wii Console
How can i test my internet connection?
Mar 25, 2011 | Nintendo Wii Console
Can not connect to a wireless internet!?
If you have a wireless connection available in your home and you have the correct password to log in, we should be able to fix this. (unless there is actually something defective in your wii)
Ok, from the menu click Wii Options(bottom left). Then Wii settings, go one screen to the right and click Internet, Then Connection settings. Click Connection One. If there is a connection one installed already then Clear it.(clear settings)
Choose Wireless Connection. Search for access point. It should search and give a list of possible access points in your area. Find yours in the list. Clik it. Input your Key or password by clicking in the blank white space. That will bring up the keypad for typing. Click OK. Click OK. Click OK to save. Click OK to test(may take a minute). If it worked you'll get a screen asking to update the system.
If this didn't work, then let us know which step failed to work.
Mar 21, 2011 | Nintendo Wii Console
I bought a used Wii which has a January date. When trying to access the settings to modify it, it tells me that I have tried to access an address which is currently unavailable. How to connect the Wii to...
click on wii button then click on wii settings then click on the right arrow head and go to internet choose search for wireless access point find your network and enter your password click ok to test connection it may ask if you want to update up to you if you do or not. you should now be on the internet
if this info was helpful please vote for me
Mar 12, 2011 | Nintendo Wii Fit for Wii
When i first got the wii it asked me if i wanted internet and i said no well how do i get the internet back?
You have to set up a wireless network for your Wii. If you already have a wireless network in your home, simply go to the settings for your Wii and go to the internet button. Search for a wireless network. If it detects your's just connect. If it doesn't then get the WEPkey for your network using the computer you set the network up on and enter that into your settings for your Wii.
Dec 18, 2009 | Nintendo Wii Console
Cant connect nintendo wii to internet
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jan 07, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
97 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
