When I turn on the computer, the cooling fan runs continuously. The windows screen does not go on the monitor
  • Computers & ... Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 21, 2011
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Laptopscreen not coming on lights and fan ok
When it is running if you hold a light up to the screen, can you see anything on the screen? What about if you connect another monitor to the computer does that work?
If you see something on the screen using a light, you have a bad inverter or back light.
If you see nothing on the screen and nothing on an external monitor, you have a bad motherboard.
If you see something on an external monitor but nothing on the laptop then you have a bad cable or display on the laptop.
Mar 09, 2014 | Computers & Internet
Gr dv900
Display problems are among the most common difficulties people have when upgrading either Windows or their computers. Here are solutions to some common display problems.
You can also try running a troubleshooter to diagnose and fix common problems with Windows Aero, which can cause display problems.
To run a Windows Aero troubleshooter
  1. Click this button:
    15ad0d89-8be7-4885-80c5-77c64a7460e6_17.pngFix this problem
  2. In the File Download dialog box, click Run, and then follow the steps in the wizard.
Show all
expcol_imgs.pngHow do I determine what is causing my display problem?
expcol_imgs.pngHow do I find out what kind of video card my computer has?
expcol_imgs.pngWhat kind of monitor do I have?
expcol_imgs.pngWhy does my monitor show only limited resolutions?
expcol_imgs.pngWhy am I seeing horizontal lines, flickering, or other strange interference on the screen of my CRT monitor?
expcol_imgs.pngWhat is DirectX and how can I troubleshoot it?
expcol_imgs.pngI've changed the resolution of my monitor, and now I can't see the display.
expcol_imgs.pngWhy does the text on my monitor appear blurry?
expcol_imgs.pngHow do I set up multiple monitors?
expcol_imgs.pngWhy do I get an error when I use different video cards for multiple monitors?
expcol_imgs.pngCan I change the brightness and contrast of my monitor?
Like us on Facebook
Stay in touch with Windows.
Share this page
Apr 25, 2013 | HP Pavilion dv9000z Notebook
Toshiba satellite P505-S8980 laptop "A
Solution 1) Set the system cooling policy to "active"
Windows has two approaches to fan control - "active" or "passive". The default option is passive, but if you switch it to active instead then the fan will turn on more frequently. You can do this by following these steps:
  1. Left click the battery icon in the bottom-right corner of the screen (See image)
  2. Left click More power options (See image)
  3. Click Change plan settings next to the Balanced power settings (See image)
  4. Click Change advanced power settings (See image)
  5. Click the + next to Processor Power Management (See image)
  6. Click the + next to System Cooling Policy (See image)
  7. Change Passive to Active for both Plugged in and On battery (See image)
  8. Do the same for any other modes you use, such as power saving mode
  9. Restart the computer
Solution 2) Keep Toshiba PC Health Monitor open
Some of the comments below sing the praises of PC Health Monitor. Apparently, the laptop fan will work harder when PC Health Monitor is open.
PC Health Monitor is already preinstalled on Toshiba computers. To open the program, just press the Windows key to open the Start menu, start typing "PC Health Monitor", and the program should appear in the search results. Click on it to open it.
Apr 07, 2017 | Computers & Internet
Fan continues running after turning off ignition
HI. This will, generally, be the result of the cooling fan switch.
The cooling fan switch on most electric fans monitors coolant temperature signals from the engine control computer. When the engine is cool, the switch opens to keep the fan from spinning. When the engine is warm, the switch closes, thus, turning the fan on for cooling.
I would advise to Inspect the cooling fans(thermal switch),wires and connections. Cooling fan switch problems are often caused by faulty wiring or loose or corroded connections rather than the failure of the switch itself. If the wires or connections are bad, replace them. If you think the switch is defective, it should be tested.
The electric fan cooling switch, or thermal switch, can be tested by placing the element in a bucket of water. Heat the water to approximately 207°-216°F (97°-102°C) and connect the switch leads to an ohmmeter(make sure to keep the switch leads out of the water). The switch should have no continuity until the temperature reaches this level. Let the water cool off below 207°F (97°C) and the switch should lose continuity. If the switch has no continuity at any temperature, replace it.
NOTE_The thermal switch is located on the top of the radiator, usually on the passenger side.
Dec 16, 2009 | 1998 Volvo C70
My laptop keeps crashing
try replacing the tower cooling fan(s)
Sep 30, 2017 | Gateway 40G / 40GB for laptops /...
Computor cutting out.....Remedy ??
As per your description, I understand that the issue is with overheating of the Notebook because of which it is turning off after running for some time.
First of all, Notebooks are not meant for heavy computing where they are designed for computing on the move and they cannot handle all the tasks we generally use in Desktop computers.
Coming to the issue, there will be some settings in the BIOS where the Notebook will be turned off when it reaches or exceeds certain temperature.
If the computer is allowed to run even at this temperatures, the Processor and Motherboard will burn causing serious damage to the computer.
First of all, check that the Cooling fan of the Notebook is free from dust so that it can spin at required speed and blow the enough air to maintain the temperature of the processor.
Additionally, see that the cooling fan vent of the Notebook from where hot air is blown away is dust free since if is blocked hot air will not go away and it will be circulating inside the Notebook making the notebook hotter and situaions will turn worst.
Blow the Cooling fan at the bottom of the Notebook and the cooling fan vent at the rear of the Noteook using Air Blower so that the dust which might be blocking them will be removed and there will be better cooling available.
Additionally, see that there is enouth room available at the bottom of the Notebook for enough ventilation.
You can also try using notebook cooling solutions like Cooling Fans which will be placed at the bottom of the Notebook and having two fans. These devices will be connected to the USB Port of the Notebook for power and blowing air to cool Notebooks.
Hope this helps...
Sep 13, 2008 | HP Pavilion dv6000z Notebook
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Pc automatic turn off
see the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Sep 12, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
