Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
Acomdata external hard USB hard drive model HD160UE5-72 worked fine then suddenly the device was not recognized. Reboot with unit powerered up and the device is not detected. Blue LED is on, tried another cable. Still not detected or recognized. Does this device need a customer driver or does it used XP driver? I do not remember as it has been three years since I installed. it.
    Top Expert:
  • Acomdata Master
  • 12,962 Answers
Either the hard drive is bogus or the electronics of the external adapter is the culprit. Take out drive and hookl directly to mo bo as a secondary drive. If recognized drive is ok and the box is at fault.
Posted on Aug 25, 2017
SOURCE: ACOMDATA HD080U2FE-72 External Hard Drive
my final solution was to remove the drive from the housing and install it as a slave in the main case. The computer is operating Windows XP and instantly recognised the drive. Works fine, all of my data is there. No problem now. This approach will not help laptop users but they might try removing the drive from the ACOMDATA housing and installing it in another housing.
redrippervf1
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: acomdata HD500uhe5-72 cant be seen . on XP
Try rebooting the computer first with the drive not connected to it.
After the computer reboots, make sure the accomdata is turned off then connect the usb cable. Then turn it on and you should get the password dialog box and be able to access it.
Posted on Apr 21, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a model HD320UHE5-72 external acomdata hard
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 18, 2009
SOURCE: Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
Posted on Dec 24, 2009
  • 109 Answers
SOURCE: Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Posted on Feb 06, 2010
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
COMPUTER DOES NOT RECOGNIZE HARD DRIVE...HELP
Hello Sir, hi, If a PC does not recognize your external hard drive, you need first to check if the USB port is working, to check simply plug another USB device such as flash drive, if the port is fine, check to see if the USB port is a version 1.1 or a version 2.0, and look if your external hard drive is compatible or does it needs a DEVICE DRIVER, A USB 2.0 device may work on a USB 1.1, just reduced speed, and last try to see if your PC is the problem and not the Hard drive, have your Hard drive plug on another PC, visit a friend and check if you could use his or her PC to see if your hard drive is bad. Now if you find your hard drive is bad, its either the Interface circuit OR the physical hard disk itself. You can check your hard disk, simply disassemble the unit and gain access to the hard disk. either SATA or IDE, plain Hard disk plug it on your PC. see if you can access the disk. If yes back up your files. your Interface circuit at this point is bad. If your hard drive is bad, buy a new hard drive, as your replacement. keep me posted
Jun 08, 2010 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
I have the western digital media player and it won't read my hard drive
Segate free agent External hard drive not recognizing as a drive
Although in device manager mass storage device is taken as drive for that.
one pop-up is coming "your usb could perform better in usb 2.0
operating system server 2003.
the same hard drive is working fine with windows XP system,but not working with server.
Jan 12, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Hard drive goes out in the middle of copying
Most of the time the problem can be solved by using a cable that is really short and of good quality.
or try another usb slot and see whether the problem repeats.
Now if the external drive is FAT (most of them come from factory as FAT formatted) and u are trying to copy files grater than 4GB, it will fail as FAT cannot recognize files larger than 4GB. SO you may try to format the external drives into NTFS, if thats the case.
Jun 10, 2008 | Acomdata 500GB External Firewire HD 500 GB...
External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Mar 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Interface problem
My drive was working fine till this weekend. It started when all of a sudden i left my hard drive plugged in my computer over night and woke up to see a constant red light and its contents cannot be read from the C drive nor on a fresh reboot. I need the contents of the hard drive urgentlllyyy or i am dead meat.... PLEASSEEEEEE HEEEELLLLPPP!!!!!
Feb 21, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
204 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
