Question about Specialized Sirrus
Hello, I have a Specialized Sirrus Elite, and I would like to raise the handlebars higher to be in a more upright position. How high can I raise them and how do I go about it? Thank you,
Handlebar stems come in many different lengths and degrees of rise to help fit the bike to you. In addition the bars could be changed to provide a bit more rise as needed.
Posted on Sep 22, 2014
    Brigadier General:
  • 8,546 Answers
  • swansoncourt Mar 28, 2011
    Thank you, that is extremely helpful. I'm new to cycling and really appreciate website.
  • David Dunn
    David Dunn Mar 28, 2011
    Welcome aboard, to cycling and Fixya.
    You may find in time that your comfort with a more aerodymic riding position will increase. If you ever have any desire to ride fast and far you need to lower your torso out of the wind you create. Contact a local bicycle club and you will probably find new friends who would be eager to mentor you on equipment, techniques and places to ride.
Fuji roubaix 3.0. How do you raise the handlebars? They are just a bit too low for me.
you can't raise the handlebar if you have the A-headset type of stem. If there is one or two bolts on the stem that clamp it to the steering column on your fork, then you have this style. To get the handlebars higher you will need to purchase a stem that has a steeper angle to it or is shorter or both and this will provide a more upright position. You LBS (local bike shop) can help with getting you fitted with the correct size for you and your bike.
Sep 13, 2013 | Fuji Cycling
Can handlebars on diamondback insight 2 be raised?
typically not, they use an Aheadset style headset. If you need them higher then your dealer or local bike shop can help you pick out a stem that has more "rise" to it so you can sit more upright.
Jan 19, 2013 | Diamondback Insight RS 700c Men's Hybrid...
I need to heighten handlebars
In the center right below the handlebars is and allen head screw. You will need an allen wrench, loosen the screw by turning it counter clockwise. Lift-up on the handlebars and adjust to the desired height and re-tighten the hex screw. Be carefull not to raise up beyond the lower adjoining yoke line on the goose neck.
Jul 11, 2011 | Specialized CrossTrail
How do you raise the handlebars on a Schwinn kicker pro bicycle?
Your options are limited. Once cut, the steerer tube can be no higher than it is.
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise
and reach might give you the added height you need. If you LIKE the handlebars, the stem
is the best option as most new ones come with front loaders (detachable front caps) that
allow replacement without stripping components off one side of the handlebar. In minutes
a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between
aerodynamics and uprightness when needed.
May 07, 2011 | Cycling
Hello, I just bought a raleigh devon 27 with alu frame. I want to raise the "steering tub" since the handlebar is to low compare to the saddle. How is this done ? Thanks, Kjell
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Apr 01, 2011 | Raleigh Diamondback Men's Edgewood LX...
I have a Sirrus bicycle made by Specialized. Is there a way to raise the handlebars?
There are a number of ways to raise the handlebar, depends on how old your Sirrus is.
The most common is too replace the stem with one that has a higher rise to it. Take your bike into your local bike shop and have them take a look at your set-up and they can offer specific options depending on how high you want to raise the bars.
NOTE: Depending how high you raise your handlebars you may need to replace your cables and housing to your controls. Also you may have handling issues if you raise the bars too high. If you are raising your bars because your uncomfortable or having pains in the neck or back you should consider getting a bike fitting to make sure you are properly mated to your bicycle.
Mar 20, 2011 | Cycling
How do u raise handlebar heigth on f400 bycycle
There are only a few ways to raise the height of your handlebars (the actual grip portion you hold onto)
1) - Raise the stem. How this is done is determined by what type of stem you have.
A. If the stem is inserted via a shaft into the frame, then you must loosen the bolt in the center of the shaft to raise and lower the stem. This has limitations (a line on the end of the inserted portion of stem) you can not go past the max insertion line. If you need it higher, then you need a new stem that allows for more height.
B. If the stem clamps around the fork steerer, then you can only raise the stem as high as the end of the fork. In some cases you can invert the stem for greater height. If you need greater height, then you will have to replace the stem with one that has greater angle.
2) - Replace the handlebars with ones that place the grips higher relative to where the bars clamp to the stem.
In all cases this would be a good project to take into your local bike shop, show them what you have and ask them for the best solution to raising your handlebars.
Things to keep in mind: When you raise the handlebars you increase the distance from the controls to the brakes and derailleurs. If you want to raise past a certain point you will need to replace your cables and housings as they will need to be longer.
DO NOT RAISE ANYTHING ABOVE THE LIMIT LINES: This will cause the bike to be unsafe and could fail causing a serious injury or worse.
Dec 11, 2010 | Cycling
What is the weight (rider) capacity for a specialized sirrus
The rider that rated this bike weighs 16 stone. http://www.bikemagic.com/review/reviewProductReviews/mps/rpn/28573/prod/Specialized-Sirrus-Sport/rcn/103/rgn/1/sp//v/2 I'm from Canada and unfortunately don't know the conversion. I used to build Specialized bikes and I know they are well manufactured. I weigh 180 but for someone in the 210 range ,they should consider 36 to 40 spoke wheels. I hope this helps.
Aug 10, 2009 | Cycling
Riding position
i agree, higher handlebars will keep you relaxed on a long ride, depending on the terrain and the riding style.
but to have an idea on what handle bars risers to get, here are the OEMs
Click on this link
Dec 06, 2008 | 2008 Honda NT700V Deauville
Specialized Sirrus Logo
1,489 people viewed this question
Top Specialized Cycling Experts
richie46
dante
Donald Ayers-Marsh
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
