Question about Microwave Ovens
I have a Sanyo SBM-20 breadmaker. The black colour plastic cam that forms part of the drive coupling broke up...don't know why.. I am trying to glue it together and, if successful, I will attach it back on to the rectangular plate that forms part of the motor drive. I presume it clicks firmly on to the plate but, due to the damage I think it won't now fit snugly..., I am therefore considering glueing it to the plate. If all this does not work can I obtain a new plastic cam and if so where can I get it? I live in China...the breadmaker was given by a friend who maybe purchased it in the UK......spares here I suspect will be difficult to obtain. My e:mail address is Keith.Barb@bigfoot.com
    Brigadier General:
  • 8,909 Answers
I would contact Sanyo.com and find a dealer in your area and if there isn't one take a look on ebay for spares.
Posted on Mar 21, 2011
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Turntable wont turn on my sanyo s7560w
Base on other microwaves I suggest that it is either the drive element or the turntable motor. If you hear the motor turning it is likely to be the drive element. To get to the drive element take out the glass plate and there will be a plastic part that engages the plate. You should be able to pull the drive element out with a little work. The receptacle of the element will likely be shaped like a circle with a flat spot. If the plastic looks deformed it is likely the drive element. Don't be surprised that they want $30 for a new one. Use glue on the drive element as a last resort. With the drive element in but the glass out run the microwave for a few seconds. Can you see the drive element turning? No? New drive motor needed. It may be expensive but it should be easy to replace.
Oct 23, 2013 | Sanyo Microwave Microwave Oven
To find Manual
As I don't know exactly the model we are talking about, I'll show you Sanyo's page, where you will find a microwaves's manual (http://us.sanyo.com/Microwaves/Compact-Microwave-Oven), I just don't if it is the one you have been looking for. If it's not, you can go here (http://us.sanyo.com/Microwaves)and look for yours.
Oct 20, 2012 | Sanyo Microwave Ovens
How can I cook for 20 seconds in SANYO MICROWAVE 1250W EM-S2587V
Go to www.sanyo.com contact customer support and the technical department to see it they can offer a solution to set it below the 30 seconds.
May 28, 2012 | Sanyo Microwave Ovens
I need a manual for a Sanyo Automatice bread maker Model SBM-20 Reply to Elizabeth Hall brigae@hotmail.com
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps
Apr 03, 2011 | Microwave Ovens
I have a Sanyo Breadmaker Factory Plus, SBM 150. I need the manual and recipe book. How can I obtain them? Thank you. Lisa
I found the manual at http://www.retrevo.com/support/Sanyo-SBM-150-manual/id/284ag617/t/2/
Oct 21, 2010 | Microwave Ovens
Oven stopped working except for the "express" button.
hello,
what is indicate i that there is a form of disconnection or loose of wire from the connection on the element i.e the heater it is silver in colour
what you have to do to fix up wave back to function is to (unscrew)open the wave then trace the wire down to the element to fine the loose wire then connecte it back to the element and then make sure there is no form of dirt or liquid form on the panel of the wave couple it back with this the problem is solve .
please when doing this put off all power supply connected to the wave.
than you and thanks for using fixa.
Jun 14, 2010 | GE Advantium SCA1001SS Convection /...
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
