Question about Apple iBook G4 Mac Notebook
I think i may have jammed two CD disks in my computer. Now they are stuck.
    Novelist:
  • 66 Answers
That's quite a problem! Generally the slot-loaded superdisk drive will prevent you from jamming a second in there so this could be a tricky operation depending on how far in you got the 2nd disk.
If it's ALL the way in it will definitely be easier for you to take it to a professional to disassemble your laptop to get to the drive and THEN disassemble to drive to allow the disk to be removed.
If it's only partially in I would highly recommend the following method of removal:
1) power off your laptop, remove the battery and unplug it. 2) using a couple pieces of paper towel or a thin towel and a pair of 5-8" pliers pinch the CD that is partially exposed between the towel. Make sure you get a firm grip on the 2 layers of towel and the cd, if it slips, reduce the number of sheets or thickness of the towel. Ideally we'll remove the disk without damaging it. 3) Once you can get a good grip that doesn't slip put your laptop on the edge of a counter or desk, place a hardcover boot on top and grip the book, laptop, and table with one hand (the book will help prevent damage to your screen) and the pliers holding the towel and CD in the other and pull the pliers away from the laptop. Hopefully it will pop out easily or with just minor resistance. 4) if you get too much resistance you might have the CD stuck on the spindle that goes into the hole of the cd, so if it doesn't budge at all I'd say a stop at a professional computer repair office is again in order.
I hope this helps! Please reply back with any further issues!
Posted on Mar 21, 2011
Dvd or cd are not open
I think you are saying that the CD/DVD drive drawer will not open?
Most drives have a tiny hole above the drawer. You need to straighten out a paper clip ,then poke it into the hole. This should release the drawer catch and you can open it by gently pulling. It may be jammed as a disk was not properly seated inside.
Check on My Computer that your computer recognises the CD/DVD player is there.
Mar 03, 2014 | Panasonic SC-PM39D System
I can't take out the dvd from the drive as that is not ejecting
you may have a label or even the metal slide piece stuck in the mechanism. Take it to a computer shop so you dont do more damage trying to open it. Some CD drives have a small reset hole on the front that when an open paper clip is inserted it allows rejection but if a lable is stuck it needs specialized intervention, especially for the 3.5 drive that has metal slide from disk jammed in it
May 18, 2010 | Acer (91.47A37.001) CD-ROM Drive
Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Apr 07, 2010 | Technics SL-PD887 5-Disc CD Changer
Disk stuck in dell precision360
at the CD tray at the battom is a small hole.... insert a paper clip in to it very carffuly amd should work
Oct 25, 2009 | Dell Precision 360 Workstation/Personal...
Same problem
Jun 21, 2009 | Acer (91.AB264.023) Internal 32x CD-ROM...
Computer will not recognize disk that is stuck in Toshida combo drive
I think you will find a pin hole in the cd cover near the button. Unfold a paper clip and insert it in the hole and that should manually eject the tray. If that is no good then the drive needs to be removed and opened to get to the label and disk.
Jul 26, 2017 | Toshiba SD Computers & Internet
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
The CD wil not eject
There is a small hole in the drive, insert a paperclip and push in to eject the drawer manually.. the disk might be stuck and jammed the drive
Dec 29, 2007 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
TRAYS ARE JAMMED
hi, there must be a disk previously inserted which has stuck in the tray or something, open the cover and check if anything is preventing the tray from ejecting.. let me knoiw
Dec 28, 2007 | Philips MCM530 CD Shelf System
Apple iBook G4 Mac Notebook Logo
55 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
