Question about Cerwin Vega LS-15 Speaker
How can i take the grill off my cerwin vega cls-12 speaker
  • Cerwin Vega Master
  • 5,568 Answers
Many boxes use friction fit male/female PVC mounts that simply pry apart.
Use an old credit card (or, if you have too many, one that still works!) and slide it in the crack between the frame and box and try prying it.
If assembled this way, it should only take moderate force to pry it away from the box.
Posted on Aug 02, 2008
I just purchased 2 12"
bigger is always better, use the 12 if you have it. higher gauge = thinner / not better.
Mar 08, 2011 | Cerwin Vega E-312 Speaker
What is the best amplifier to use to drive the cerwin vega cls 215 speakers?
optix422000,
Use a "real" amp, not a receiver as your CV's need real power to perform the best. Check the following links for some choices. I use the first as it's a monster for low-end.
http://www.adcom.com/prod/shopdisplayproducts.asp?prodid=1322
http://www.crownaudio.com/amps.htm
http://www.us.onkyo.com/model.cfm?m=A-9555&class=Amplifier&p=i
Remember to shop online wisely and only purchase from a authorized dealer.
-Chris
Aug 15, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
Speakers to amp
With the CLS-215 speakers, you can Bi-Amp or Bi-Wire them.
Here is how to Bi-Wire and Bi-Amp Speakers:
http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
Jul 13, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Cerwin Vega D9-E Speakers. Bad crossovers...I think. Fixable?
Crossovers are made with wire coils, electrolytic capacitors and resistors.
Capacitors may get leaky or blown with time and heavy use, and are quite easy to find, just be sure to use the same polarity, capacity and voltage rating and to respect the polarity if it's a polarized capacitor.
There may also be a burnt out resistor or a coil. Resistors can be obtained and replaced (same resistance and wattage) and wire coils can be rewound (same amount of wire of the same wire gauge).
Another possibility is a partially damaged wire on the speaker itself. This is the braided curl wire that goes from the speaker membrane to the cable connection lugs on the speaker armature, and it may be damaged at the membrane side or the lug side.
It usually happens from what you call "overcooking".
To repair this it will require some soldering skills, but it's a bit hard to solder that type of wire, as it tends to oxydize and is difficult to clean prior to soldering, it may be difficult to access it, depending on the speaker structure(an alternative to this is to replace the speaker itself).
There may be some physical damage to the membranes if the sound is present but is of a bad quality (a slightly damaged membrane may be repaired using some rubber glue, but it will never return the speaker to the original condition).
These are just some suggestions, hope they can help you get closer to a solution.
regards
3rq8 (triarcuate)
Jul 23, 2009 | Cerwin Vega CLS-12 Main / Stereo Speaker
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Cerwin Vega LS-15 Speaker Logo
116 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
