Question about Denon AVR 2808Ci Receiver
Cant get my sub to work on my denon avr2808 and dont think it ever has it doesnt even work on the test signal
    Top Expert:
  • Denon Master
  • 75,462 Answers
Hello
There are four possibilities that the subwoofer doesn't gives any aoutput. They are:
• Subwoofer's power not turned
on.
•The "Subwoofer" setting at
"Speaker configuration" is set to
"No".
•The subwoofer is not properly
connected.
•The subwoofer's volume is
turned off.
Go to its manual setupscreen, come to speaker setup, speaker confuguration, come towards Sub Woofer, select "Yes" and press OK.
Posted on Mar 21, 2011
No bass from Bose AM 15 Sub
Sub will only work in surround mode, not stereo mode. Also source must have sub component (5.1, 7.1, 9.1 etc) If your system was transmitting sub signal before, be sure you have chosen a mode which includes a sub signal.
Nov 11, 2013 | Denon Audio Players & Recorders
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
My Denon AVR 589 does not seem to send any signal to my sub, I have try another working sub and it does the same. I just notice this week that my sub was not working. I have check on the amp setting and...
Is there a switch on the back of the receiver that will switch the sub signal from digital to analog? And the same switch might be on the subwoofer itself.
Hope that helps if not just reply back.
Thanks
Dec 23, 2010 | Denon AVR-589 Receiver
Unable to get my sub to work with my Denon AVR 1506 Receiver
Did it ever work? Are you certain the sub is getting a signal. It has to be defined. How about the speaker levels adjustment? Did that work? Give us a clue.
Jan 28, 2010 | Denon AVR-1506 Receiver
I am planning on buying Denon AVR 1909 receiver. Can hook it up with Bose Acoustimass 6 speakers. DOes the Denon blow up the small bose speakers. If yes how do i hook them up.
on the am 6 by bose you have to use all the supplied cables or you will blow them. the way it works is that all the speaker signal/power from the denon goes directly to the sub, then the sub sends the signal to each speaker. if you do this correctly the sub takes what it needs and sends the rest to the smaller speakers. and you wont blow them unless you hook them directly to your reciever.
Jul 30, 2009 | Audio Players & Recorders
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
No surround sound from my Denon 3805
well as long as all signals are routed through the Denon your on the right track, now what else you have to do is connect all devices to the reciever do not loop one device through another. Also you have to try the different surround fields to hear the one you like the best for music I use 5Ch stereo for movies the surround field varies based on the type of movie
Feb 01, 2009 | Denon AVR-3805 Receiver
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Oct 26, 2008 | Denon AVR-3300 Receiver
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
Denon AVR 2808Ci Receiver Logo
630 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
