Question about Dell 2 Button Mouse 6u226
How to reassemble delll vostro USB mouse. i opened for cleaning now not able to reassemble it.
DELLL VOStRO pc MOUSE FROZEN
unplug mouse and replug into a different port.
Apr 14, 2014 | E-Machines eMachines Desktop PC
My LogiTech mouse stopped working. I cleaned the laser and everything. I have a USB plug and I blew into it to clean it but it still won't work. I don't know much about this but I need help.
Hi, I had a similar problem with a microsoft usb (wired) optical mouse. I shut down my computer and pulled out the usb cord. Mine has four thin rubber pads on the bottom. I removed the two farthest from the usb cord, and underneath each were two screws. I removed those, and then was able to carefully open up the mouse. Inside I found a small chunk of black plastic, that possibly broke off of something. I dumped that out. The usb cord plugs into the circuit board inside through a connector. I partially pulled the connector out of the board, then re-seated it. I also blew puffs of air into the optic (probably an LED). I cleaned the scroll wheel with a Q-tip dipped in alcohol, and cleaned anything else that needed it with a Q-tip and alchol as well. I reassembled it with the screws, stuck the pads back on (still sticky), plugged it back in and booted up my PC again. Now it is working very well if I use it on a black 3-ring binder (not a floppy one, a hard one). I don't know which thing I did was the trick, but it might help you or others. It still doesn't work well on white (paper for example). The connector may have gotten loose, or the plastic chunk may have been blocking the optics.
Aug 31, 2013 | Logitech Internet 350 USB Keyboard
Dell Vostro with XP - cursor is running rogue and endlessly going backward.
This "can" be malware, but is most likely your pointer device going wonky. First unplug the mouse, trackball, or whatever it is you are using for a mouse. If you are still using an old PS2 connection (round plug), consider getting a USB mouse to replace it.
Plug your mouse back in and see if it solves the problem.
Try a new mouse.
If it's not the mouse (you just said the cursor is moving) it could be that the left arrow on your keyboard is stuck. In that case, rake your keyboard, tap ******* the arrow keys, turn over the keyboard and shake out any large Cheeto crumbs, use compressed air (if possible) to blow the dust out.
Unplug your keyboard from the computer and plug it back in. If you are still using the old PS2 keyboard (round plug), consider getting a USB keyboard to replace it. *** warning
*** warning, do NOT throw out the old PS2 plug keyboard if you replace it. You may need it to get into the BIOS some time in the future if the electronics don't recognize a USB keyboard on boot.
Feb 07, 2018 | Dell Vostro 1520 Notebook
Touchpad and mouse Vostro 1720
No any software problem but fist you tray USB mouse and that's mouse Is working minis no problem in sotward so after you Chang your laptop touch pad .....
Mar 01, 2011 | Dell Vostro 1720 (bqcwd1z3) PC Notebook
Where/how do I install the Logitech receiver to get the Logitech wirelless mouse and the wireless keyboard to operate. Where does the green circular mouse plug to on a Dell Vostro CPU?
most PS/2 type mouse and keyboard sockets are color-coded on the CPU's back panel.
violets are for keyboards. greens are for mice.
if it's usb type, plug it to any available USB port. it will be plug and play.
for wireless keyboard and mouse, you need to place the receiver away from any metallic objects so as to lengthen it's range and sensitivity.
Nov 15, 2009 | Logitech Cordless Mouse
Sticky mouse button
my friend you can open your mouse, first you need to find the screw in your mouse. Then after you find the screw used a screw driver to open it and in order to open you have to remove all screw. then When you open your mouse kindly clean it remove the mouse board and blower it to dry also make the entire mouse dry before you back the mouse from it proper formation.
Thanks
Jul 01, 2009 | Microsoft SideWinder Mouse - Mouse - laser...
Touchpad dell vostro 1000
your touchpad may just need cleaned
or have you shut it off or disabled check control panel and mouse then device settings if you see enable then click and apply
don't forget to rate me
thankx
Feb 01, 2009 | Computers & Internet
Microsoft Wireless Notebook Optical Mouse 1023 Need Driver
i wanna know about Microsoft Wireless Notebook Mouse model 1023, is there any driver software need to that mouse, please tell me sir
need a driver, mouse works but USB doesn't light up
Jun 21, 2008 | Microsoft Wireless Notebook Optical Mouse...
Dell 2 Button Mouse 6u226 Logo
41 people viewed this question
Alun Cox
