Question about Sanyo DP50747 50 in. Plasma TV
What cable do i need to connect my laptop to my Sanyo DP50740?
  • 24 Answers
A VGA cable. Also know as a 15 pin D-SUB.What cable do i need - tech_av_0.jpg
Once you have connected the laptop to the plasma - you may need to activate the external monitor on your laptop. How to do this is dependent on your laptop manufacturer and the Operating system you are running ie Windows XP, Mac OSX.
An example of the function key and which F key to press is shown below.tech_av_1.jpg
Posted on Mar 21, 2011
Where is reset button on sanyo 50 inch tv model DP50740 The TV will not stay on
There is no reset button on televisions. I see that is a plasma set, if you are just losing the picture that is one thing, if the whole set is shutting down, that is another. Please advise
Feb 02, 2016 | Sanyo Televison & Video
I own a 50 inch Sanyo modelo DP50740 it turns on the only problem is that the buttons on TV don't do anything and the controller doesnt do anything as well please help
Check and replace the main system control memory I. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 05, 2015 | Sanyo Televison & Video
Dp50740 power led goes on and off
What you have is most likely a failed main board. These sets are known for this problem. There are several different variations of the main boards. Make sure you order one that matches yours. The main board part # will start with J4@#. The main board part # should be on a sticker either on the main board itself or on the coax input terminal casing. I hope you got the TV for a good price !!!
Sep 01, 2012 | Sanyo Televison & Video
Sanyo dp50740 will not come on after power surge is there a reset?
Connect TV to a different power outlet and try. Switch off TV manually, remove plug from power outlet after switching off power, and retry after 48 hours. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Sanyo Televison & Video
Sanyo dp50740 wont come on after power surge
Change power outlet and see. If problem persists, it might need attention by a qualified service technician.
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
I just hooked up my Memorex MVBD2535 Blu-ray player to my Sanyo DP50740 plasma bia an HDMI cable. The picture flashes on and off, and sometimes the screen says "no signal". I know the Sanyo...
I had this exact same problem after setting this model DVD player up. I put in a disc thinking I would listen to the movie while working on some other projects and would call tech support in the AM.
Putting in the disc fixed the problem. If there is a disc in the system, I do not have this issue. If thee is not, it does the same thing while it is on.
Jan 04, 2011 | Memorex Televison & Video
How do i delete channels from sanyo tv that i do not want to watch?
On my Sanyo DP50740 you, go to Menu, select Channel Setting, select Channel Scan memory, then just go to the channel in the list that has a check mark by it and push enter to remove the check mark and it will no longer show up when you flip through the channels but you can still access it by entering the number manually.
Nov 20, 2010 | Sanyo Televison & Video
Sanyo DP50747 50 in. Plasma TV Logo
130 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
