Question about Conair 1875 Watt Hair Dryer #247Red
I have a Conair 1875 Silver and black hair dryer. I took it apart to clean the wire meshes and once I removed the screws in the handle, it came apart but all the parts fell out at the same time. I am having a heck of a time trying to put it back togther. Do you have a diagram of what it supposed to look like inside the handle and where the pieces go? Much appreciated if you do. Thanks
Http://www.youtube.com/watch?v=KsR4Pb8R1AU&list=UU3pxfTP6v3CKeIzLZJfRxdQ&index=2&feature=plcp
Posted on Apr 07, 2012
2 Suggested Answers
rb77x7
  • 62 Answers
SOURCE: Where can I find an
I found a list of all their instruction booklets for hair dryers (some are 1875 watts) but they don't have the Yellow Bird:
http://www.conair.com/cnt_ib.php?action=filter&type=category
You could try calling Customer Service at 1-800-326-6247, or ask for the instructions via the online form here:
http://www.conair.com/customer-service-cn-18.html
Good luck, and I hope this helps!
Posted on Jul 01, 2011
How do I remove the back screen from my hair dryer to clean the lint?
Most hair dryers are split in half ruining around the unit. Remove screws in handle the pull the two sides apart. Blow all the dust out of motor and fan. Do this every once in a while and it will last a long time.
Aug 21, 2016 | Generic Revlon 1875W Tourmaline Ionic...
Vidal sassoon vs505 disassemble
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Mar 23, 2014 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
Conair Ion 1875 hair dryer won't go on
did u try pressing the trouble shooter on the cord if that dosent work
take it back
Dec 05, 2012 | Conair Health & Beauty
Where can I find an online instruction manual for the Yellow Bird Conair Pro 1875 watt blowdryer, please?
Jul 01, 2011 | Conair YB075W HAIR DRYER 1875W YELLOW BIRD
This dryer does not appear to come apart in any way in order to clean out the lint. Can you tell me how to do this?
Good for you! Cleaning out the lint is the only way to keep your dryer from burning out the motor. And you're right, it won't come apart. I have had this dryer for years, thanks to cleaning out the vents.
First, UNPLUG YOUR DRYER.
I've found that my slightly-curved manicure scissors are the easiest tool to use for cleaning these vents. With the scissors closed, I use the pointy end to scrape up the lint, using a rocking motion-- don't scrape all along the vent, you'll only compress the lint into the mesh. Sort of how you would ice a cake: dab and lift. It's okay if you don't get absolutely all of it out, just do the best you can. If you can't find manicure scissors, a toothpick or a large, un-bent safety pin (be careful!) will do.
Apr 30, 2011 | Conair 1875 Watt Ionic Folding Handle...
Wires burned inside handle.
This is most likely caused by a short circuit. It's dangerous to use as it could go on fire or melt the handle and electrocute you. It's best to get rid of it and get a new one.
Apr 17, 2011 | Conair 1875 Watt Ionic Folding Handle...
I need maual for Revlon 1875 IONIC hair dryer Model # RV479 i want to download the PDF manual if possible
Well you may please follow the link below to get your manual -
http://www.conair.com/instruction_booklets/1875Watt_Ionic_Styler_146XR.pdf
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Vacuums
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Conair 1875 Watt Hair Dryer #247Red Logo
2,723 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
