Question about Sony MUTEKI HTDDW1600 Theater System
I just got a sony muteki htddw7600 does it matter if i plug a 5.1ch dvdplayer into it or will it sound like **** ?
    Brigadier General:
  • 8,546 Answers
Sound 'quality' is in the ear of the beholder. It accepts coaxial digital audio and HDMI connections.
Read some reviews...
http://www.productreview.com.au/p/sony-ht-ddw1600.html
Posted on Mar 21, 2011
I have a sony muteki 7.2 it is only 6 months old and never had a problem. I turned it on today and the LCD says usb fail and it turned itself off. Please help????
Firmware problem. Contact the authorized service center for Sony. If you wish to get more details, Google for this site " Electro help".
Apr 23, 2015 | Sony Televison & Video
Sony Muteki 7.2 USB Fail error, no USB plugged in
Sony Muteki with USB Fail message or turning on and off is generally related to a faulty mains input relay. Search for it in the schematic and replace with a stronger part. Sony uses a very weak relay to connect the mains after power button is pressed. It doesn't last too much.
Sep 19, 2013 | Sony MUTEKI HTDDW1600 Theater System
My wife says that the muteki 7.2 chanel does not need to be going all the time um something todo with the over useage of power so how do i just run the tv without the muteki going as it wont go meani
You can turn off the 7.2 channel surround sound system if you only want to listen to audio on the TV channels, you may need to increase the volume levels on the TV.
Use the 7.2 channel surround sound when you want surround sound when playing DVD movies.
Jan 10, 2013 | Sony MUTEKI HTDDW1600 Theater System
Sony htddw7600 turns on then flashes protect an turns off
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Sony MUTEKI HTDDW1600 Theater System
Will the Muteki sub amp work with a different receiver that has no trigger.
My subwoofer recently burnt out because I had it plugged into a different amplifier.. I wouldn't recommend it. Sony has released the sub to suit that system.. Do keep in mind that I did have bass boost on with the sub up full (Which didn't matter when I had it connected to the Sony amplifier..).
Proceed with caution.. I would recommend turning the sub down and using the sub volume control on the amplifiers settings to change the volume.. Just do not run it at a pace where it looks like it is stressing.. When I say stressing I mean, looking like it is going to jump out of the enclosure..
-Dubkingz
Aug 17, 2011 | Sony MUTEKI HTDDW1600 Theater System
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Sony Home theatre system 7.2 Channel Muteki HTDDW-7500 Problem : No sound output from speaker. Power supply, Display & Channel Sellector all function in normal. I have test with Headphone plug-in to...
If headphones are not working when you have unit properly set to the input you are using then there is something seriously wrong with the receiver. Is the monitor button incorrectly on?
Aug 25, 2017 | Sony Audio Players & Recorders
I have a sony HTDDW7600 or 8500 there is absolutely no sound coming out of the unit, i checked the manual for the trouble shooting and the only thing i could think of was something about a protective...
Is it alive but silent or just plain dead?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 19, 2011 | Sony MUTEKI HTDDW1600 Theater System
Sony MUTEKI HTDDW1600 Theater System Logo
401 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
