Question about Mitsubishi Televison & Video
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel of the TV. I tried unplugging the Unit and waited for about 15 to 20 minutes before turning it back on , still won't work. I tried using the original remote for the TV to try to turn the power on, still doesn't work. There is a reset button beside the timer light, and I tried to reset the unit, and still won't work. Please help
  • Mitsubishi Master
  • 8,457 Answers
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Posted on Mar 21, 2011
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
Nov 29, 2012 | Televison & Video
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Mi mitsubishi 55859 has flashing green light that won't stop flashing and tv won't turn on
Bad digital/power module. Difficult repair. Have an authorized shop pull module and ship to Mitsubishi for rebuild. Many many caps are bad inside, and probably bad digital board. Factory service is recommended.
Jan 18, 2011 | Mitsubishi WS-55909 55" Rear Projection...
I have a projection TV model ws-55909 that will not turn on. The timer light blinks for ten seconds and then shuts off?
the problem on ur tv could 2 problems , if the keep blink all the time is the digital box the problem to fix the digital box u have to replace 7 capacitor on the power supply inside of this box , now when u press power and the blink on then goes off the ploblem is going to bo the convergence ic pl;s 2 pico fuses part #stk392-570
Dec 02, 2010 | Mitsubishi WS-55909 55" Rear Projection...
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
The tv will not turn on. mitsubishi ws-55909
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point, is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Mitsubishi WS-55909 55" Rear Projection...
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
