Question about Samsung RS2630SH Side by Side Refrigerator
Hi Fridge side fan was noise for 3 days and now
Hi Fridge side fan was noise for 3 days and now it's not working, the temp in fridge side (20C); Freezer ok (-18C). Please advice, Tnx. Andy
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Posted on Jul 19, 2012
  • Vincent English
    Vincent English Sep 26, 2012
    When you defrost the fridge and put all back together 24 hours later, should the fan in the fridge kick in straight away? only mine is not doing.
    Sergeant:
  • 194 Answers
Www.azmanual.com/manual/.../samsung-rs2630sh-refrigerator-manual
Posted on Mar 21, 2011
This is a Kitchenaid KSRS22FGBL00 - The freezer works good with a temp of -20c but the fridge side is not cold & has a temp of 8c. There is no frost build up anywhere. The air vents are not blocked. ...
Hello hlook,
I understand that you are having a problem with your side-by-side refrigerator. The Frezzer is staying closed and the fridge is not getting the air flow from the freezer in order to stay cold. The only possibility it can be is the fan. The fan may be turning but not at the rpms needed to move the air in to the fridge. As I have looked at the air flow chart for your fridge that is the only outcome I can come up with. CLICK HERE to view the air flow chart for your firdge.
With the cover off of the fan try and judge how much air is being moved by the fan. It should have pretty good air flow like the low setting on a box fan. You should be able to fell the air flow from two to three feet away.
Thank you for choosing FixYa.com
Justin
May 03, 2011 | Refrigerators
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
Freezer is not cold, defrosted everything,fans running,back sealed so cant get to any coils.making a clicking noise.flipped circuit breaker .never had prob before temp settings are on coldest settings ...
Is the clicking noise coming from the back side bottom ofthe fridge? If so its the compressor trying to kick in. Usually this is a death nail for a fridge. You say the fan is running is the fan inside the fridge fzr running and is there a fan under the backside of the fridge running? let me know and I will be glad to help more. Hope your day gets better
Aug 16, 2010 | Refrigerators
We have a samsung side by side fridge freezer dispenser model and the fridge side has stopped working but the freezer does appear to still be functioning. The fridge temp control keeps restting itself to...
Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
Mar 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
Liquids frozen in refrigerator, no water from water dispenser
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Kenmore 53642 / 53644 Side by Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Jul 19, 2009 | Hotpoint HSS25GFP Side by Side...
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
368 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
