Question about Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups
Cannot get the top cover removed so I can troubleshoot the electronics. All accessible screws removed. Seems to be some sort of catches where the side and top covers come together at the rear. Anybody done this before?
    Sergeant:
  • 194 Answers
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
clean light glows, turn the coffeemaker on by
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
mode. One cycle should be sufficient to
adequately clean the coffeemaker. When the
cycle is completed and the five beeps sound,
the coffeemaker will shut off. Turn the
coffeemaker ON to see if the Clean light
continues to flash. If it does, turn it to OFF and
then repeat the cleaning procedure with a fresh
solution of vinegar and water.
If the Clean light no longer flashes, turn the
coffeemaker to OFF and then run one cycle of
fresh cold water through the unit before using
the unit again to brew coffee.
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OF
Posted on Mar 21, 2011
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Fault code 40 on fisher paykel washing machine
Hi -
Code 40 - is Bowl Fault
The electronics has sensed that the bowl is not engaged.
Check the following - Mechanical.
1. Check that there are no foreign objects causing the bowl to malfunction. As it fills up the inner bowl will disengage from the outer bowl. It will sort of freewheel as so to speak.
2. If empty of water, carry out a clutch disassembly procedure and check spline drive. - removed center of agitator, unscrew middle of the agitator a screw, remove the screws on the top pf the inner bowl to separate, will need to remove the top though to do this, usally two rubber bungs on the front screws under and the rear is normally plastic clipped/lock setup.
3. Next check that the pressure tube has not come off and that it is not kinked. - check the clear tube by blwing into the bowl as you remove the top electronics cover (2) screws top rear - do not blow into transducer on the controller module.
Electronics - if all else fails - Replace Motor Control Module.
Jun 12, 2011 | Fisher and Paykel GWL11 Top Load Washer
Help!! Subaru Legacy Horn Cover Removal. I have a 1991 Manual 1.8L selective 4WD Subaru Legacy Sedan. I need to remove the light/washer stalk assembly, so I am pretty sure I need to remove the steering...
If your steering wheel is the soft grip type, just grab the left hand side of the horn cover near the bottom and give it a firm pull. It should just pop off at thr bottom, then pust it up to slide the clip off. It can be tricky to get back on though, just spent 20 minutes trying to get the clip to catch. If it's a different type, I have no idea. Good luck!
Jan 28, 2011 | Subaru Legacy Cars & Trucks
How do i remove the back of washer to rplace the fill valve?
Most Maytag's let you remove the FRONT and the TOP, rather than the back--
This is better, since you don't have to pull the washer away from the wall, (unless you have to get to the water valve fixture...)
To remove the front,-- look down toward the bottom of the Front cover-- Do you see a ridge?-- and two screws hidden out of sight?, sort of just below that ridge?--
Can you remove these 2 screws?
This allows the cover to drop slightly, and now you can see the two catches that allow both the top and the front to be removed--
See the catches?-- they are about 1-1/2" wide-- They connect the top at the front, to the front panel. Inserting a putty knife, or thin bladed screw driver, allows you to push BACK on these catches, and the front then can be lifted up, and the front panel can be removed. Note the Top hinges on pivot points in the back.
This should give you good access to the water valves, and other controls.
Let us know how you make out--
Mack B
Jan 17, 2011 | Maytag MTW5700TQ Top Load Washer
Dryer not working, PF fault.
The fault code PF means a power failure occurred or the power to the dryer was interrupted by any means while it is running. The interruption can be due to a power outage/failure or a power cord loose connection to the electronic control board. Pressing the Pause/Cancel button clears out the display; otherwise, unplug the dryer then let it sit for at least 15 minutes.
Remove the three hex-head screws from the rear flange of the dryer top cover to access the machine control electronics and check the power cord connection if the issue is not resolved above or if the fault code keeps on popping up. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover. Lift the rear of the top cover and slide it back so the tabs clear the catches on the bracket, and remove the cover from the unit. Make sure that the tabs slide under the bracket catches when you reinstall the top cover.
Remove the three screws from the machine control electronics board bracket and pull the bracket away from the side of the dryer in order to access the connectors. Visually check P1 harness, the five-wire harness on the upper left corner of the machine control electronics where the power cord connects and make sure the connector is fully inserted into the electronic controls and the terminal connections are clean. Reseating the connection several times will help clean off dirt and corrosion build up in the connection
The
machine control electronics definitely needs replacing if the issue is not addressed by the outlined procedures above.
Jul 18, 2010 | Whirlpool GEW9200L Electric Dryer
I need a diagram on how to remove a heater core in a 1994 mercury villager
big job. entire heater plenum has to come out. 6 hour job.
http://groups.yahoo.com/group/villagerquest/
Instrument Panel Removal
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE BACKUP POWER SUPPLY ENERGY MUST BE DEPLETED BEFORE ANY AIR BAG COMPONENT SERVICE IS PERFORMED. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY GROUND CABLE AND WAIT 10 MINUTES.
    Disconnect the battery ground cable (14301).
  1. Remove the access cover from the bottom of the steering wheel (3600) and disconnect the driver side air bag module electrical connector.
  1. Open the glove compartment, then pull the access panel from the top of the glove compartment. Disconnect the passenger side air bag module electrical connector.
  1. Remove the four console compartment plastic screws or C/D changer cover plastic screws (if equipped) and the console compartment door (045G36) or C/D changer cover.
  1. Remove the two LH inner instrument panel lower cover screws and the plastic nut.
  1. Remove LH inner instrument panel lower cover (044L97) and disconnect the foot lamp electrical connector.
  1. Remove the two RH inner instrument panel lower cover screws and the plastic nut.
  1. Remove RH inner instrument panel lower cover (045G22) and disconnect the foot lamp electrical connector.
  1. Remove the plastic screw, two lower screws, two center bolts, two upper screws and the screw at the instrument panel bracket, then separate the glove compartment from the instrument panel (04320). Disconnect the glove compartment striker plate catch electrical connector.
  1. Remove the two instrument panel to passenger side air bag module bracket bolts.
  1. Remove the four passenger side air bag module nuts and the passenger side air bag.
  1. Remove the RH instrument panel screw.
  1. Remove the four C/D changer screws.
  1. Remove the C/D changer and disconnect the C/D changer electrical connector.
  1. Remove the instrument panel ash receptacle (04810).
  1. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  1. Remove the center instrument panel finish panel and disconnect the cigar lighter socket and the cigar lighter illumination lamp electrical connectors.
  1. Remove the two instrument panel ash receptacle bracket screws and the instrument panel ash receptacle bracket. Disconnect the instrument panel ash receptacle lamp electrical connector.
  1. Carefully pry the center A/C register from the instrument panel.
  1. Remove the hose from the ambient temperature sensor and disconnect the ambient temperature sensor electrical connector (if equipped).
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result. Refer to Module Service Procedures in Section 18-01 .
    Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel.
  1. Disconnect the three radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  1. Remove the plastic screw, the two instrument panel steering column cover screws and the instrument panel steering column cover (04459).
  1. Remove the four LH instrument panel reinforcement bolts and the LH instrument panel reinforcement. Disconnect the diagnostic electrical connector.
    Remove the instrument cluster (10849). Refer to Section 13-01A (electronic cluster) or Section 13-01B (conventional cluster) for the removal procedure.
  1. Disconnect the seat belt warning chime electrical connector. Remove the two seat belt warning chime screws and the seat belt warning chime.
  1. Remove the four steering column nuts and lower the steering column assembly.
  1. Remove the two LH instrument panel screws.
  1. Remove the center instrument panel screw.
  1. Remove the LH inner duct screw and the LH inner duct.
  1. Disconnect the power outside rear view mirror control switch electrical connector.
  1. Pull off the upper portion of the LH inner door opening weatherstrip. Remove the windshield side garnish moulding (03598).
  1. Pull off the upper portion of the RH inner door opening weatherstrip. Remove the windshield side garnish moulding.
  1. Remove the instrument panel upper moulding (04268) and disconnect the sun sensor electrical connector (if equipped).
  1. Remove the light sensor amplifier from the top right side of the instrument panel and disconnect both light sensor amplifier upper and lower electrical connectors (if equipped).
  1. Remove the instrument panel center nut.
  1. Remove the two instrument panel upper bolts.
  1. Remove the instrument panel from the vehicle.
May 20, 2010 | 1994 Mercury Villager
Remove printer cover from HP laserjet 4L
you want to remove the top cover? there are four screws on top, and four catches, two in front and two in back. if i remember correctly, you also need to open the access door in the back.
Jun 16, 2009 | HP LaserJet 4L Printer
Change the lightbulb
should be one screw on the back side of the machine top right if facing the back, remove that and you can get the side cover in front of the needle bar off, you should have easy access to the light
Jun 02, 2009 | Brother XL-2230 Mechanical Sewing Machine
Want to remove cover of Krups Espressario XP7240
Yes it is tricky but easy once you know it. remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute lid. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. You filter is the white valve connected to the three way valve (white plastic). You remove it by twisting it 15 degrees. Clean the inner parts (valve and spring) from coffee debris.
Feb 01, 2009 | Krups Small Appliances Espresso Machine
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups Logo
273 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
