Question about Intel D102GGC2 Motherboard
When i will do some work in my pc some times the processor fan is rotating to fast and a lot of sound is coming what is the problem can u help me sir
  • Intel Master
  • 32,281 Answers
The heat sink may be clogged with dust and ifthe BIOS temperature sensor controls the fan speed then it may be compensatingfor the reduced cooling by the dust build-up.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Posted on Mar 21, 2011
    Scholar:
  • 114 Answers
Dear Umashankar Ji,
Don't worry this is not a problem.
This is due to overheating of processor just like we have a radiator in our Cars.
Fan starts when the car is heated up. same case with the processors and their fans.
so dont worry.
Thankyou
Gagan Gupta
My dell optiplex gx 620 system fan run so fast and produse a lot of noise when i play games or downloading data from net
Open up the computer and clean the dust out of the fan and processor heat sink. If it is a temperature-controlled variable speed fan, it will probably not have to work so hard to keep the processor cool.
If it is a fixed-speed fan, it may be getting loud because the bearings are wearing out. Gently try to rock the fan blade unit - it should not have any wobble or slop in the bearings, and it should rotate easily.
If necessary, clean as much dust as you can out of the power supply without taking it apart.
Do not use a regular vacuum cleaner to **** dust off the motherboard. The high-velocity airflow may generate electrostatic charges that can damage the board. It's probably OK to vacuum out the heat sink if you hold the fan still to keep the vacuum cleaner from over-speeding it.
Apr 29, 2011 | Dell OptiPlex GX620 PC Desktop
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
My computer comes on and then immediatley shuts off the starts the process over. Doesn't have time to even try to boot.
1.Processor may be overheated,because the processor fan may not be rotate.
if processor fan is rotating then...
2.Remove the Hard disc power connector and data cables then try to on the computer.
3.Remove the Cd/Dvd drive power connector and data cables then try to on the computer.
4.Remove any other drives connected with your computer.
5.Remove the printer,scanner,mouse,keyboard connected with your computer.
thank u .... now u can find the problematic device. All The Best...
Apr 22, 2010 | Dell Dimension 2350 PC Desktop
Computer Beeps When Windows is Loading
First, you should be sure that the cooling fans are working properly. Especially the one that is on or directed to the processor. You'll need to open the system up to check this. Turn on the system and make sure all the fans are spinning fast. Now, check for lots of dust or dirt on the fans and processor heat sink. Most likely, the inside of your tower needs to be cleaned. If there is too much dust and dirt in the fans and on the processor heat sink, it can't cool itself and the system shuts down to prevent damage to the processsor once it gets to a certain tempature. I have seen this often. You will need to use a can of air on the fans and processor heat sink. There will be a lot of dust and dirt that will come flying up....which is good Then use a vacuum and a soft bristle attachment to get out the remaining dust. Put the system back together and you should be good.
Your manual should show you how to take the cover off your PC to access the motherboard.
I hope this helps you.
Apr 08, 2010 | Dell Dimension 8200 PC Desktop
WHEN I START MY PC MY CPU FAN TURNS ON AUTOMATICALLY
Some models are designed this way. Other boards will increase the fan as the processor gets hotter. I would recommend leaving the fan always running as fast as possible. Processors and other components in your PC put out a lot of heat, and heat is your enemy, shortening the life of your pc.
Mar 15, 2009 | Microsoft Windows XP Professional
Noisy fan - ~Dell Dimension 5150 (3 years old)
This issue is discussed here: Click Here
As for the fan check it inside the pc sounds like you may be missing a screw
Mar 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My lap i making more sound
you're right the sound is coming from around where the CPU is but thats not making the sound,, more than likely its your fan (located on top of the processor)
Oct 05, 2008 | HP Pavilion dv6000z Notebook
CPU Heating Problem
Actually, when you play 3d games, it takes a lot of processor usage, thus more heat is generated from the processor. The system compensates this heat by increasing the speed of the fan. Try downloading a sensor for your processor(usually available in the drivers CD or the motherboard's website) to check if the heat is really over the limit. If it is, you may want to clean your fan, put some oil, and replace the heatsink compound. Or if you have extra cash to spare, buy a better cooling system for your processor
Sep 18, 2008 | Intel D101GGC Motherboard
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Intel D102GGC2 Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
