Question about Bosch Axxis WTA 3500 Dryer
Dryer heats and runs but clothes are not completely dry. the lint light comes on. have cleaned lint out of dryer including behind and underneath
  • Bosch Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Aug 13, 2011
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
LG Dryer Problem DLE6977S doesn't heat/dry clothes. The check filter is flashing but the filter has been washed. What else can I try? Cooling light is on as well, but not flashing.
there is a sensor located underneath the lint trap, gently clean it off, you may want to disconnect the vent tube and run the dryer as the vent may be restricted. Tim
Apr 17, 2011 | LG Dryers
Clothes come out mostly dry, but need to run a 10 or 15 more minutes to completely dry. Towels need 2 drying cycles. Lint filter is clean. Lots of lint behind dryer and I notice a lot of lint on...
you need to clean out the dryer.somewhere lint is blocking the air movement.pull off the vent line,if it's long blow it out with a leaf blower,then clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.if it's gas you should do this once a year electric once every two years.
Feb 17, 2011 | Dryers
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer will not keep constant heat
clean your vent that goes out side Thats what does that the hot air dosent go outside but comes back on the temperature control and shuts the heat off. Also if you put wet close it it the lint will be built up behind the fan. You have to lay the dryer down take the back off and fron the bottom on the left side is the vent foller the hoe to the left. there is four 5/16" screw hokling that tub on thake those screws out and raise that unit enough to get you hand to the fan blades and you will find two hands full of linte matted there.
clean that out dryer need good air flow be sure to pull youi vent out the top and clean before each dry.
Apr 21, 2010 | Whirlpool LGB6300 Gas Dryer
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
108 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
