Question about Sony Ericsson W200i Cellular Phone
Navigation key is not working - Sony Ericsson W200i Cellular Phone
    Sergeant:
  • 194 Answers
Remove the panel and clean the joystick still problem persists replace joystick
Posted on Mar 21, 2011
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Lincoln Navigator key fob and garage door opener quit working
I'm not sure, but I would assume there is a module involved
Mar 06, 2014 | 1998 Lincoln Navigator
I need to set up a security code to delete my recent calls how so i set one up
From the home screen press the RIGHT SOFT KEY (Soft keys are located above the center navigation key on the Right and Left sides, usually denoted with a horizontal line on the key)
Scroll to the SETTINGS option and press the CENTER NAVIGTATION KEY to make the selection.
Scroll to the PHONE SETTINGS option, and press the CENTER NAVIGATION KEY to make the selection.
Scroll to the SECURITY option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the PHONE LOCK option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the desired option, then press the CENTER NAVIGATION KEY to make the selection.
THE DEFAULT SECURITY CODE IS 0000 (4 zero's)
To change the current code, scroll to CHANGE CODES, then use the CENTER NAVIGATION KEY to make the selection.
Scroll to desired code, then use the CENTER NAVIGATION KEY to make the selection.
Enter the security code, then use the CENTER NAVIGATION KEY to confirm the code.
You will be prompted to enter a new security code, ENTER THE NEW CODE and use the CENTER NAVIGATION KEY to confirm the new code. You will do this twice. I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
Jul 11, 2013 | LG A340 MobiPhone - Silver AT&T A340
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How to reset samsung s w299
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
The navigator 6710 won't work as a phone only the navigation switches on. When you switch it on the screen does not show the menu or the contacts. Noen of the keys work except the start for navigation.
amazingly the auto zoom in out is not a software problem.. it's hardware problem nd that's is why nokia is not getting in to help as its gonna cost it alot. the problem is that the upper portion has become touch sensitive. the acceot key , hang up key,the two selection keys and the navigation keys are made touch sensitive "delibrately" or intensionly.
Feb 03, 2010 | Nokia 6710 Navigator Cell Phone
My navigation keys do not working properly
It might be your navigation key has a loose connection to your cellphone that is why sometimes it does not work properly... I am recommending you that you must change your cellphone casing
Jul 30, 2009 | Nokia N72 Cellular Phone
Keypad buttons ( navigation keys only) not working
Both navigation keys and number keys stopped working
any ideas
Aug 18, 2008 | Nokia 6500 Slide Cellular Phone
Navigation keys act like menu access/confirm key
get to the security options and set factory defaults the code is 00000000 eight zeros
rate me
Jun 08, 2008 | Samsung SGH-ZV40 Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
67 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
