Question about Labtec Spin 55 Computer Speakers
Speakers have been working fine for a couple of years, suddenly cut out and im not sure if they are broken or not, have all the updated drivers, have tested other speakers so its not my sound card.
  • Labtec Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 21, 2011
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I've been having an odd issue with my speakers on my computer. After some perfectly fine use, playing music, games, etc, the left speaker suddenly stops putting out sound. Plugging in my ipod, both...
Intermittent problems are always the hardest to diagnose but I would start by going to the device manager and deleting the sound drivers. Then a reboot and as your machine restarts it will reinstall the soundcard drivers and if the game has corrupted the drivers that should your your problem. Should it continue you will need to find updated drivers for Windows 7.
Aug 29, 2010 | Audio Players & Recorders
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
No sound from speakers
Check to see if your computer settings arnt muting your speakers
Check to see to if the audio driver software isn't muting the speakers as well
Oct 17, 2008 | Logitech Z-2300 Computer Speakers
Very low audio
Hi Sir's / Mam,
In order to resolve your issue you would need to do the following steps:-
1.Update latest BIOS and sound drivers.
link for BIOS update :-
http://support.euro.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=1&impid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=
click on this URL and before any steps are done please save your work and also check in BIOS battery charge should be more than 10% in BIOS and Ac Adapter should be connected and make sure that there should be no power failure during this process.
Update the Sound drivers:-
http://support.euro.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=3&impid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=
After the BIOS update try to update the sound driver on the link mentioned above.Even after both the updates don't give results call Dell Tech Support and based on the HW warranty get the motherboard replaced.
Also try and connect to external speaker and see if the issue is same or different??
Sep 11, 2008 | Dell Inspiron 6400 Notebook
Sound
First make sure it is not muted. You can also check and maybe update the sound card drivers.
It's also possible that it's a hardware problem, e.g. broken speaker wires.
Dec 05, 2007 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Labtec Spin 55 Computer Speakers Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
