Question about Emerson LD195EM8 19 in. LCD TV
When i hook up my ps3 to an emerson 19 in tv with an hdmi cable it says format not supported
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Emerson Expert
  • 177 Answers
LCD Emerson only support screen with a 1440 x 900 720p resolution.
And PS3 has support 1080p or full HD.
You must arrange output HDMI resolution to 1440 x 900 or to 720p.
thanks.
Posted on Mar 21, 2011
  • 1 more comment
  • Basuki Jrobenk
    Basuki Jrobenk Mar 21, 2011
    You can setup resolution from PS3:
    Try this:
    WITH NO DISC INSERTED* If there is one, eject it and turn the system off so I can show you from a system start with no disc. This IS using a HDMI cable as well
    1)Power on system; do NOT push any buttons on the controller!
    2) Over 4 to the left
    3)9 down
    4) Click 'X' once
    5)Click 'X' again
    6)Click 'X' again
    7)Click 'X' again
    That should bring you to some settings list that makes sure that the settings you clicked were what you want
    Or push power button 5 - 10 minuts, than setup resolution to 720p.
  • trackrat09 Mar 21, 2011
    even with no disk in it says unsupported format. I cant even get it to work with any of the other cables for the componet or the regular video, so in that respect i cant reformat the ps3. thank you but i need more info or advice.
  • Basuki Jrobenk
    have you reset your ps3 by pressing power button 3~5 second or longer ?.
    Because It will reset the PS3 so that you can adjust your res. settings.
I am trying to hook up my PS3 into my room (Emerson 22 inch flatscreen with HDMI) I am plugging it in with the HDMI cable when it says "Resolution mismatch!" Is that because it was previously on...
This is because your Emerson does not support full HD (unlike your 52").
To fix this:
i) Make sure your PS3 is off (showing red light) ii) Hold down the power button for 5-6 seconds until you've heard two beeps
You should now be able to reset your video options - make sure 1080P is not checked and you should be able to use your PS3 fine with your Emerson.
When you reconnect to your bigger TV, do the same trick with the power button again and turn 1080P back on.
Mar 06, 2011 | Video Game Consoles & Games
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Format not supported
Are you trying to connect this with red white and yellow rca cables or hdmi? if you turn off the ps3 and hold down the power button it will reset itself to the factory settings for the tv out put.make sure ou have rca connected firs.
May 17, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi generates a not supported format error message on my emerson lcd tv
your ps3 is set to work on a 1080p tv you can change the pixel setting on your ps3 by holding the power button down while youe console is running until it turns off let go and hold your power button down again when your console turns back on your tv wil ask you about the hdmi device its found unless you failed, good luck n00bs
Jan 10, 2010 | Emerson Televison & Video
Every time I try to play my PS3 with my HDMI it says that the format is "not supported", unless i jiggle it for a half hour until it works, but then the tv goes off and on when you try to play. how can i...
Your TV cannot support 1080p that the PS3 is sending out to the HDMI, try lowering the PS3 resolution. A lot of people have this probelm if you Google the PS3 VIDEO issue.
Dec 17, 2009 | Emerson LC320EM8 32 in. LCD TV
Trying to hook up HDMI to PS3 and the TV keeps saying not a supported format
Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
Oct 21, 2009 | Sylvania LC195SL9 19 in. LCD TV
PS3 dont work
Go through setup on your PS3 with a normal AV cable and un-check the higher resolution boxes (1080p and down) one at a time, unless you know specifically what resolutions your television supports. After un-checking, plug in the HDMI cable and see if it fixes it. Basically, you need to set the PS3 to a supported format for your television.
Jan 31, 2009 | Sylvania LC195SL9 19 in. LCD TV
Just wondering if you could tell me the best way to set up the TH42PZ70BA LCD Television to get the best results from the PS3
This is very easy. Just hook up your PS3 to your TV via HDMI cable and set your TV and PS3 to 1080p resolution. On the PS3 all you have to do is click "Display settings" and then go to HDMI output AFTER you have hooked it up. Just click on 1080p and 720p because some games do not support 1080p resolution. Hope this helps!
Dec 29, 2008 | Philips 19PFL5622D/37 19 in. LCD...
Emerson LD195EM8 19 in. LCD TV Logo
2,118 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
