Question about Optoma PK102 Projector
I can't seem to figure out how to get the information from my computer to the projector. How do I get the info from my pc to the projector
    Sergeant:
  • 194 Answers
Convert all the powerpoint slides to jpg first and then use the onboard media player's slideshow feature
Posted on Mar 21, 2011
Our projector shows a blue background and does not seem to be connecting to the computer
Several things to check.
Make sure both the input selection on the projector is for PC and make sure the PC output selection is for the external output, as in an external monitor. The PC does not care or need to know that the external output is a monitor or projector.
If none of these works, try a different cable and output on both the laptop and projector ie, Switch from PC output to a DVI or HDMI.
Nov 22, 2014 | ASK Proxima Office Equipment & Supplies
System Volume Information folder keeps appearing in my usb flash drives. I can see it when I plug into my game console but not on the computer. Everytime I delete it on the console it ends up back on there...
its system generated folder
this folder appear when u plug a USB drives in different OS based computers make it delete every time or use that drive in same computer every time
Oct 25, 2013 | HP Computers & Internet
My infocus projector is working but image freze for few sec pe min, where is the issue Thank you dan
The issue is in the image source. Not in the projector. the way the image is processed ( digitized) occurs at the media source and spooled to the projector in easy to read streams. The projector doesn't get to think about it, rather just fill its pixel roster and let the light shine through. So change the source of the image and the symptom will change.
The issue of reading and streaming digitized information is handled in different places in different machines. Video card on some computers, mother boards on others, Info is read organised acording to the projectors driver (stored on your media source drive) cashed (packaged) to be spooled (feed) to the projector in the way it likes it matching it's clock cycle. Maybe your driver has a bug.
Feb 21, 2011 | InFocus LP70+ Multimedia Projector
Cant get picture to come up on screen? We had it working at one time but cant seem to figure out how now. We are using a HDMI cable. thanks
1. ensure the projector is set to video and not another source eg. computer. this will ensure it is receiving to the correct connector.
2.ensure the transmitted signal is able to be received on another device such as tv or dvd recorder. if not suspect cable or settings on transmitter.
3 if a home cinema system is between the tranmitted signal and the projector ensure that it is on and it is set to the right setting.
i hope this helps
Dec 11, 2010 | Mitsubishi HC1600 Projector
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Dell 2200mp searching for signal
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Sep 25, 2007 | Dell 2200MP Multimedia Projector
Projector and pc not picking each other up
Hi, Normally your connection should work straight out. Pls verify that your dvi output is enabled/activated by checking your display properties. In a Windows based OS machine, right click on any clear area of your desktop, click on Properties. Click on the settings tab, Advanced button. Check on the different abs such as Monitor, display and others. There should be an indicator for dual view or enabling/activating your secondary display unit (which is your projector). Hope this be of some idea/help. Post back how things turn up or should you need further information. It may also be of help if you can provide info on your PC. Good luck and kind regards.
Sep 23, 2007 | LG DLP Projector 1400Lum RD-JT30...
Optoma PK102 Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
