Question about Lexmark X6170 All-In-One InkJet Printer
Lexmarkz730 printer my pc recognizes the printer is installed but will not let me download. I can't find the install disk
    Champion:
  • 221 Answers
Lexmark's website should have the software you need !
Posted on Aug 06, 2008
Hi, I have the card Printer Edisecure DCP340+ it was working perfectly, I just format my PC and tryed to install it again ! The problem when i connect it to any PC it is recognized as DATACARD SP55
If you re-formatted the PC, then you likely wiped out the instance of the correct driver for your printer. Windows typically does not come with a driver for any but the most popular ID-card printers. When you reconnected the EdiSecure printer, it likely associated it with what it believed to be the closest driver to the one required (but missing) - the Datacard driver. To correct:
1. Through the Windows Control Panel, then Device and Printers (or Printers and Faxes if WinXP), find the instance of your printer (set up as Datacard); right-click on it; select "Remove Device" (or "Delete", if WinXP);
2. When complete, disconnect the printer from the PC;
3. Through Windows Control Panel => Programs (Add/Remove Programs if WinXP), find and un-install any instances you find of Datacard programs or drivers;
4. Reboot your PC;
5. From either the printer's install disk, or the manufacturer's website, download and install the correct driver for your Windows OS. If prompted to re-boot, do so. NOTE - do not connect the printer to the PC until you are either prompted to do so by the driver-installation program, or the installation completes normally and without errors.
6. Connect the printer to the PC. Give Windows time to recognize the device, associate the new/correct driver, and tell you it's ready for use.
7. Check in the Windows print center (Control-Panel=>Devices & Printers (or Printers & Faxes) to verify that it is now recognized as an EdiSecure printer.
Mar 31, 2015 | Datacard Office Equipment & Supplies
Need to connect my printer kodak esp-3 to my laptop using a usb cord
Install the software for your printer on your laptop. Then connect the usb cable to the printer and the pc will recognize it. Then just print as normal. The pc will not recognize the printer until the software has been installed. If you have lost your driver disk, you can download a free copy from Kodak's website.
Oct 25, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
No connection with computer but printer is recognized
Try this, Disconnect the USB printer connection.
Remove the printer from the printer list. The list should be empty.
Re-boot your computer.
Check and make sure their are no other printers in list.
Find your install disks for the printer.
If you do not have a install disk, go to HP and download the printer installation files.
Install the software and do not plugin the printer until it is asked for.
After you install the new drivers and software the printer should be seen by the computer.
Sep 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Lexmark x1270 - have had this printer since february and it has worked fine up until now. When I turn the printer on the power light just flashes green (blinks). I deleted it from my printers folder and...
Now that you deleted the printer you need to reinstall the driver either from disk or from the download.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Dec 02, 2008 | Lexmark Computers & Internet
I have a Lexmark 5470 printer. I can't install the printer because the disc won't work. I just spins around and the computer doesn't recognize that it is in the drive. I have tried it on other computers...
If you do not have the disk you download software from Internet, follow instructions below,
A web page will open, follow instructions, select operative system etc., and click on download .
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Download driver from website and run the file.
Note some printer does not work on Vista.
Sep 23, 2008 | Office Equipment & Supplies
Need downloads so computer regonizes printer?
I have just purchased a new Dell computer with Microsoft Vista and I cant seem to get the installation disk to install program.
Sep 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
Do not have installion disk for lexmark x85
You didn't specify the operating system you are using.
However, drivers can be downloaded here, directly from Lexmark:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X85
IF you are using Windows Vista (you will see there are no Vista drivers listed), people have reported success using Windows 2000 drivers on Vista.
Be sure to UNPLUG the printer from the PC before installing the software. Only plug it in when the on-screen instructions tell you to do so.
Apr 08, 2008 | Office Equipment & Supplies
Installing printer
Are the Windows Vista drivers on the disk? If not you can get them on the link below: http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista Try reinstalling with the new driver. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
