Question about HP LaserJet 6L Printer
When I try to print a test page on my laserjet 6l I get an 'error - printing' message in the print queue box.
    Scholar:
  • 114 Answers
Dear friend this could be because of not installing the printer properly or data cable not connected.
for this you have to uninstall and then reinstall the printer now click on the printer properties and click on ports, here you will see a long list of ports installed scroll up or down and make sure the (tick) mark is in on the "LPT:" (measns LPT: is selected) if this configuration is correct then check the data cable remove it and connect it again to both CPU and the PRINTER. only these two problem can do this other than a printer motherboard problem. if your problem did not get solved by this then you need a technician who can repair your printer.
Thankyou
Gagan
Is that Useful? Do reply me with the results.
Posted on Mar 21, 2011
    Sergeant:
  • 187 Answers
You need to reboot your computer to reset all print in queue window. After that try printing again and that probably will solve your problem.
Please rate if you find this helpful.
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
Printer says "ready" but won't print
try checking cable if you have another cable try that after rebooting computer! if that doesnt work go to hp's website look up the units driver for the correct operating system reinstall the drivers from hp's website then reboot and try your printer again it should work! 99.9 percent of time error printing to queue is a communication problem from the driver being corrupt or a error in your system registry.
good luck!
Jul 12, 2010 | HP Color LaserJet 2600n Printer
I bought a Laseret 6L and a usb adaptor cord to replace the parellel port connection on the computer end. I've tried every suggestion regarding ports, but nothing works. The test page prints OK, but...
I've heard there is special software needed to do the USB to parallel conversion. We have a customer using a LJ 1000 with this hook up and there is supposed to be a driver/conversion software that handles the issue. Here is a good discussion that may have some solutions for you.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1268956879623+28353475&threadId=1087380
Mar 18, 2010 | HP LaserJet 6L Printer
Problem with printing on HP 6L
Make sure the parallel port is enabled in 'setup' (bios) (make sure to exit and save even if no changes were made). If you are running 'Vista', you may need to update the driver from HP.
Aug 24, 2009 | HP LaserJet 6L Printer
HP Laserjet 1160 and Vista
Download update from HP on Vista.
Jul 11, 2009 | HP LaserJet 1160 Printer
LaserJet 6L Prints Outlook content too light
You can run into these problems when using non OEM toner cartridges. It sounds like anything that is printed in a light gray is not printing correctly.
Apr 28, 2008 | HP LaserJet 6L Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet 6L Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
