Question about GE JASRM24912 Remote Control
None of the codes listed works for my panasonic television. None of them will allow me to use the channel or volume buttons and only one of them allowed me to turn the tv off. Now that one doesn't even allow me to do that. I have used dozens of universal remotes in the past and this is by far the Lamest product I've ever used.
    Top Expert:
  • GE Master
  • 75,169 Answers
Hello
I'll give you some universal remote control codes for Panasonic to check it with your remote control They are used as general universal codes for panasonic.
Three digit universal remote codes to check with are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit unvicersl remote codes to check with are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 21, 2011
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Jdvillanueva
Nov 23, 2011 | Panasonic Televison & Video
Need code for samsung tv on a GE universal remote 24912
Most GE remotes use the same codes for particular brands of television. These are the standard codes for Samsung TVs:
0105, 0077, 0076, 0109, 0007, 0009, 0004, 0005, 0085, 0172, 0942, 0358, 0012, 0015, 0080, 0104, 0106
Try each one with the power, volume and channel buttons. If one doesn't work, or only partially works, try the next in the list.
If none of these work, please post back and I will try to find a specific code for you.
Please rate this solution if you find it helpful. Thanks.
Oct 17, 2010 | General Electric Universal Remote Control
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
TVTECH Universal Remote (3 Devices)
i got a universal remote it dont have my code in the book i have a durabrand tv do you have any i deal what the code is
Nov 08, 2007 | Televison & Video
Panasonic omnivision tv/vcr combo
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Oct 10, 2007 | Panasonic PVQ-M2509 Combo
GE JASRM24912 Remote Control Logo
440 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
