Question about GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating
How expensive it is to repair (self-repair, or repairman)? It sounds OK when I rotate it manually (watched the YouTube). It's a 7-year old microwave. Should we be replacing it?
    Problem Solver:
  • 21 Answers
I fixed my own GE turntable by replacing the motor. You can purchase the part (#WB26X10135) directly from GE for $34.75 plus tax and shipping ($8.95) or from RepairClinic.com for $24.90 plus shipping ($6.46) and no sales tax except for delivery in Michigan.
The part is easy to install. Just print out this drawing to see where it goes (look for part 43) underneath the unit. Of course, be sure you unplug the oven first!
Hope this helps!
Posted on Aug 07, 2008
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Coupler has stopped turning
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
But first you should also be sure that the internal cooling fan is working, because in this model, that's where the stirrer and turntable motors get their power - from a tap on the cooling fan motor!
Probably the easiest way to check this is to remove your stirrer cover, place a cup of water on the tray, then microwave for about a minute.
Watch through the glass and see if the metal stirrer is slowly rotating.
If not, the problem may be a bad cooling fan.
It is vital that the cooling fan runs, or the magnetron will be destroyed, too.
If you're not sure how to remove your stirrer cover, it's covered in your owner's manual.
If for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE JVM1660 Microwave Oven
Sharp Microwave turn table turning irregualrly
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can probably find an exploded view and order parts by entering your model number here: http://www.searspartsdirect.com
Sharp parts are usually less expensive when ordered from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Microwave Ovens
Spacemaker xl 1800 turntable
By hub drive, do you mean the turntable coupler?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Russell hobbs microwave turntable wont turn
Is there an option via the Help or Custom Help to turn the turntable off and off?
This feature is common in over the range models.
Otherwise, it may be a bad motor.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
Please write back with your model number if you need further help.
May 20, 2008 | Microwave Ovens
Turn table on Microwave oven not moving correctly
You can usually find helpful exploded view diagrams and order parts for GE models by entering your full model number here: http://tinyurl.com/gv383
May 14, 2008 | GE Microwave Ovens
Lg lrm 1250 microwave
Some over the range models allow you to turn off the turntable via the keypad. Counter top models usually don't.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
May 12, 2008 | LG LRM1250 Microwave Oven
Microwave turntable grinds and tries to rotate but doesn't. It is a GE Spacemaker jvm1650cho1.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Mar 25, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
174 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
