Question about Arris SURFboard SB5101 Cable Modem
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
  • 32,281 Answers
To change from Static IP address to Obtain IP address automatically.
Open Control Panel - Network Connections - Right click on the Wireless network connection or LAN network connection - then click Properties - Right click on Internet Protocol (TCP/IP) - click Properties
Then click on General Tab and select -
Obtain an IP address automatically
AND
Obtain DNS Server address automatically
click OK to enable settings.
Posted on Mar 21, 2011
    Novelist:
  • 150 Answers
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
I am trying to figure out how to connect my Linksys WRT54GS2 router to my Hughesnet HN9000 modem. I have already attempted what hughesnet website told me to do and it didn't work. I have it set up...
DHCP and static IP are two different things. DHCP assigns IP addresses, and static Ip just means that the IP address stays the same, and is not dynamic. You probably need to reset the modem to accept what it sees as a :"new" router. Turn off both router and modem. Restart the modem first, give it a minute to boot up, then turn on the router- in that order. It should be ok now.
Mar 11, 2017 | Cisco Linksys WRT54GS2 Wireless-G...
Cannot connect e4200 to isp..just loopback address
You shouldn't be connecting the device directly to your ISP, but rather to a modem that is connected to the ISP. The modem will then handle the NAT for your network and your E4200 should be able to pick up a private IP address using DHCP from your modem. Or you can set a static IP on your wireless router as long as that address is available and on the same subnet as your modem. You should also exclude any static IP addresses from being handed out over DHCP so you avoid IP addressing conflicts.
Jun 10, 2011 | Linksys E4200 Dual-Band Wireless-N Gigabit...
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Xbox 360
  1. First, turn your Router off and wait for a couple of minutes (unplug power from the wall)
  2. Turn off your modem (unplug power from the wall)
Reboot both the devices and they will obtain a new IP address.
Let me know.
Jul 09, 2009 | Microsoft Wireless Network Adapter Xbox...
How do i change my sb5101 motorola modem to bridge mode? so i can start using my netgear router
You shouldn't have to change anything except on the router. Cable to modem, Ethernet from the cable modem to wan port of the router, Lan ports to PC's. Instruct your router to use cable and not dsl, set acorrdingly to DHCP or static IP, set MTU to 1500 and go...
Jul 09, 2009 | Arris SURFboard® SB5101 Cable Modem
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
No wireless light
Have you tried to check the IP address that you are getting from the router on your wired computers? If they are getting an IP address of 192.168.1.10x and the DG: 192.168.1.1 then that is the right address to get in to the router. Did you try to ping the address? did get replies? try to also disable the firewalls on your pc.
Jun 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Arris SURFboard SB5101 Cable Modem  Logo
394 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
