Question about Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum
My vacuum is not working properly, it is not sucking any dirt. What should i do? where should i take it to fix it. i already checked the hose and it is not clogged
  • 3,400 Answers
Remove hose an look down into tube that connects hose. There's a small elbow on the bottom that clogs easily. (Mine has multiple times - dog hair)
Posted on Mar 21, 2011
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
Vacuum not sucking from the brush bottom
Probably clogged at the intake. remove rug plate and check intake. Broken belt is other possibility. #5 belt. This a ver basic vacuum, so not much to go wrong.
Jan 02, 2014 | Dirt Devil M084600 Dynamite Bagless...
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Dirt/hair not passing through properly
The key to these machines is the velocity of the air flow. If any filter or hose is plugged in the system due to age or sucking something up that was wet, it will slow the air down and it wont 'spin' the debris and then it will get sucked up in the secondary system. Check all of these and if you still have problems then its time to replace filters.
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not sucking the dirt.
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Panasonic MC-V9620 Canister Vacuum
My bissell 3120-3 is not sucking up dirt
if the vacuum is not sucking up dirt first check the hose to see if there is suction if you dont have suction there you need to follow the hose to the nearest connection remove the hose from there using screwdriver or some models will twist off check to see if there are any blockages, make sure the bag is not full if so replace bag with new one if needed, if bagless or if that dosent resolve the problem remove the cover plate for the roller, remove the roller and check the suction port that routes the dirt and debris to the dirt cup or the bag. you will just need to check all of the different routes to the bag or dirt cup, the best thing to have is a blower and you can blow through the different passways untill the clog is blown out, thanks I am sure that this info will help everyone if in alb visit the Vacuum Doctor, Don the doctor is always in!!!!!!!!!!!!
Oct 31, 2009 | Vacuums
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
Jan 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum Logo
115 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
