I have WD 1 tb which is not being recognized I just upgraded to Win 7 It is working on other laptop with win 7 but not with mine All usb ports tried
  • Jason J Mar 21, 2011
    Hopefully I can help, but first I need you to provide me with a little information. Go to start, then right click on "Computer" and click "Manage" From there go to "Disk Management"
    With your external hard drive plugged in, and turned on give me the information that it says here.
  • 38 Answers
1. Make sure the USB cable is snug and tight on both sides of the harddrive. 2. If the harddrive has an external power source, make sure that it is plugged in a grounded wall outlet. 3. Ensure that the proper Win7 driver is loaded for the device. Go to support.wdc.com/download and search out the proper device and driver for your operating system. If enclosed in a .exe file, continue to install the proper driver. If the problem isn't solved continue forward. 4. If in Win7, press the start button, right click on my computer, and select manage. 5. A new window will open, select device manager tab. 6. Find the harddrive if it is connected and right click. Select update driver. 7. Should all else fail contact technical support listed at the site listed above.
Posted on Mar 21, 2011
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
ST310005EXA101RK
I would contact Microsoft about that. Hopefully the original drive has not been erased of formatted.
May 22, 2014 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Seagate expansion 2tb
Cause:
This problem is caused by an issue with the Windows 7 Backup and Restore utility when using drives with 4K Logical sector sizes, which are found on WD 2.5 TB and larger external drives. This is different from an "Advanced Format" (AFD) drive which use 4K physical sector sizes. AFD drives should not cause this problem.
Solution:
It is still possible to use a 2.5 TB drive or larger with Windows 7 Backup and Restore, as long as you don't need to use the drive with Windows XP. Using the WD Quick Formatter tool, select the Factory Default configuration to reformat the drive.
Warning: This tool will erase all data on your drive, so take the necessary precautions.
After formatting the drive to Factory Default mode, the drive will be usable in Windows Vista and Windows 7. However, the drive will not be recognized in Windows XP. This is the only way to get Windows 7 Backup and Restore to work correctly.
Jan 30, 2014 | Computers & Internet
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
Jan 11, 2013 | Western Digital 1TB WD ELEMENTS USB...
Win 7 64bit will not recognize mg6220 printer scanner
try getting a different usb cable,also try a different usb port
Oct 24, 2012 | Canon PIXMA MG6220 Multifunction Printer -...
My asus g73jh has no sound and all usb port not recognized. I reinstalled everything(win 7, bios update, driver,...) but still don't work
For the sound, try going to
Control Panel > Sound > Playback
or
Control Panel > Hardware and Sound > Manage Playback Devices
and right-click speakers and select "Set as Default Device"
Jun 18, 2012 | ASUS G73JHA1 Notebook
Upgraded to win 7, now the black cherry, Signature 320 is no longer recognized and will not download a driver, is one available for Win 7, will not run in compatability settings.
No driver is required to use the drive. Try another cable or another port on the computer. If you are using it bus-powered, try using a USB "Y" cable as some computers cannot provide enough power through one port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 01, 2011 | SimpleTech Signature Mini 320GB External...
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
WD Element 1 TB on Windows 98SE system
You can NOT access 1TB under Win 98SE, It is unable to "Address" that much memory, it is simply mathematically impossible. You have to upgrade to a system that CAN address that much memory, such as a 32 Bit system. better still a 64 bit system.
Mar 03, 2010 | Computers & Internet
WD My BOOK 1 TB only shows 20 mb when connected through Belkin N+ wireless rounter. I have a WD 1 TB which is FAT32 and works fine when connected directly to my WIN 7 laptop. But when I connect it to a...
The problems you are having is that 32 bit addressing will only provide a maximum volume size of 20Gb. If you can reformat, you’re NAS device as NTFS this may help.
Feb 07, 2010 | Belkin N1 Vision Router
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
