Question about LG 55LE5400 TV
I'm having a problem setting up my Wifi in my 55le5400. I have already bought the LG usb to Wifi, but it keeps telling me that my gateway is wrong. I called Belkin and they gave me some numbers to put in and it still doesn't work. Help please.
4 Suggested Answers
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Posted on Mar 01, 2009
SOURCE: my new LG LE5500 does
Hi Sachin...I am facing the exact same problem. Just want to know if you were you able to fix this problem or not ?
Posted on Dec 19, 2010
  • 162 Answers
SOURCE: I just bought a LG 55le5400 TV. How do I hook up a
You can use rca cables to hook it up or use the toss link cable if your receiver has that.
Posted on Mar 14, 2011
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 16, 2016 | LG Electronics 55LE5400 55LE5400 55 LEDLCD...
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
LG 55le5400 remote does not work, front panel does not work, it's stuck on one of the OTA channel. All the lights in the front panel are on. fresh battery on remote. the only way to turn off is un
If you do not have the owner manual either Google the model number for it or contact LG.
This set may have a lock out feature that locks out both the remote and the buttons on the set.
Also if have not tried it--unplug set for a while and power back up which may allow it to reboot.
Jun 10, 2012 | Televison & Video
I just bought a LG 55le5400 TV. How do I hook up a older receiver that does not have HDMI, or sound for my speakers?
Mar 14, 2011 | LG 55LE5400 TV
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Wireless
1) A working WiFi adapter, USB or PCMCIA.
2) A Wireless signal to connect to.
Windows already has built in WiFi software.
Jan 27, 2008 | Gateway 450ROG Notebook
LG 55LE5400 TV Logo
102 people viewed this question
