Question about Frigidaire FRS26R4A Side by Side Refrigerator
How do I access the defrost thermostat for a frigidaire model FRS26ZRF
  • 122 Answers
It's in the freezer section behind the access panel. towards the top of the evaporator. usually at the top of the evaporator clipped to the line.
Posted on Mar 21, 2011
Ref Frigidaire model plhs69eesn no defrost I check evap fan defrost thermostat and heater element this parts are ok but no defrost
If you have checked all that and you are sure they are ok then it could only be on the p c board some board use transistor or a relay component which is faulty
Oct 08, 2013 | Frigidaire Refrigerators
Frigidaire Freezer Upright model #: FFU11FC2CW0 Freezer is not freezing anything only keeping the food cold but not frozen. Can hear the fan running when the door is opened there is also a thin sheet...
Sounds like one or more of your defrost components are bad. Those components are defrost heater, defrost thermostat, and defrost timer or board depending on model.
Nov 13, 2017 | Frigidaire Freezers
I cannot find the defrost timer on my Frigidaire FRS3R4EB3; I've looked at manuals online and still can't figure it out. Anyone know?
You don't have a timer you have an adaptive defrost control which controls when it defrost. If your heater and defrost thermostat are ok then the control is bad. Part 23 on this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153839&diagram_id=1247647#d1247647
Nov 22, 2010 | Frigidaire Refrigerators
I have looked all over that frs26zrf but have'nt found anything that resembles what i think is a a defrost timer.
In some units they are near imposable to find...some are located in side the freezer unit up top,you will have to prise out little plastic cover plugs to unscrew the unit.the timer may have seized up,turn it and feel if it turns freely.
Jul 27, 2010 | Frigidaire Refrigerators
Model FRS26ZRF---Water forming ice block on bottom of freezer
I ll tell you whats going to happen . the clean coils will helt it to freeze up sooner . that part is good / but the ice problem is a defrost problem caused by the heater or defrost control failure . so keep on working your not done yet .. .you will find the heater and defrost terminater inside the fack of freezer .. mm
Jul 06, 2010 | Frigidaire FRS26KF5C Side by Side...
Ice In Freezer Vents
thick frost on the back wall indicates a defrost problem, either with the defrost control, the heater, or the bimetal thermostat. Without personal inspection, i cant tell you which one it is, but i can narrow it down to those three
Mar 01, 2010 | Frigidaire FRT21H7AS Top Freezer...
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
Freezer is running but the items are thawing and not freezing
it could possible be the defroster unit going out on the thermostat theres a hole on the bottom where you can access a screw that will allow you to check and see if the defroster is working put a srew driver in the hole and turn it clock wise till you here it click and then listen for the unit to start defrosting cycle you'll hear a hissing like sound if its working if not you'll need a new defrosting unit
Jul 09, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
224 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
