Question about Gateway FPD1975W 19" LCD Monitor
My screen has recently begin to flicker intermittently.
    Novelist:
  • 107 Answers
Try hooking the monitor up to another computer and see if you experience the same problem. If you don't have another computer, attempt to hook up another monitor to the same computer and see if you experience the same problem. If the problem sticks with this and only this monitor, then more than likely you have some bad capacitors in the monitor, which may be replaceable but require a bit of work to fix. Else you may be looking at a new monitor if this isn't under warranty any longer.
If the problem happens with another monitor on this same computer however, it sounds like you have some video card issues and you probably want to look into getting a new one of those.
Posted on Mar 21, 2011
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Flickering screen for Samsung LA40R81BHX/XSG
Resolder all of your boards ,Poor Solder Connections can cause this.
Jan 21, 2013 | Televison & Video
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Screen flickering
I've had a couple of problems with mine, what it usually is is the wires coming loose, I've also had to replace the screen.
May 20, 2012 | Toshiba Satellite L505-S5966 Notebook
Acer laptop screen flicker. intermittent. more at start up
Hello,the flicker on your laptop is as a result of a faulty screen or screen connector(Flex).have an authorized service personnel have a look at it.thanks
Aug 20, 2011 | Acer Computers & Internet
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
My picture is begining to flicker and there is
Have you replaced the lamp recently? If not the lamp is the first suspect on a picture that flickers...
Nov 11, 2009 | Toshiba 42HM66 42" Projection HDTV
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Flickering Lines
I recommend you call a shop and ask them how much it will be to replace the Convergence amps STK-392-110(2are in the set) 99%shure thats your Problem Good Luck Walter Grzybowski
Sep 24, 2006 | Toshiba 50H82 50" Rear Projection...
Gateway FPD1975W 19" LCD Monitor Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
