Question about Haier HLT71 7 in. Portable TV
Is there any way to add more channels or delete them after auto-programming?
  • Jeff Seale Mar 21, 2011
    Thanks. First time I've had a portable TV of this type.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
Haier HLT71 is a digital TV, that meanthis tv can recive digital broadcast.
A digital tv have 8 program each channel. Not like analog tv that only 1 program each channel.
So, if you want to save 1 channel , 8 channel will automaticaly saved as well.
Thats imposible to save or delete from your program.
Posted on Mar 21, 2011
  • Incorrect.....MOST DTV statons use 3 or 4 "subchannels"...a DTV carrier is a 19MB signal...the broadcaster can determine how to divide it between subchannels..the first (x.1) is usually the HD,...sometimes 2 or 3 are HD....depending on the bit rate, etc....Each "subchannel" is treated by the TV as a separate channel...go to menu, channels and look for channel list or delete channels...in that area, you can mark the subchannels you wish to remove...also under search, there is usually a selection to search for NEW channels...With MOST Haiers, merely going to the analog channel (which may or may not match the digital channel) and see if there is any signal there...if there is, the TV will auto add it and all subchannel...IE: In my area, there is a channel 25 that is 6.1 (the original 6 moved to 25 for its digital channel)...if I tune my Haier to Antenna 25, after a sec or two, it shows 6.1 and I can scroll up to 6.2...and saves them in the channel list...If the HLT is the model I am thinking of, it can also still pickup some analog signals (Low Power analog stations are allowed to stay analog until Sept 2015)...too bad its not HD but it does look great on its digital screen..the Haiers seem to have some of the best tuners (I have a 32in Haier that has the same tuner...I am amazed how well it picks up!)
My channels have all been deleted. Need an easy quick way of getting them back
Look in the menu for "autoprogram" and settings for set to be cable or air for what you are using.
Auto program should scan and store all available channels. Most sets have a manual add or delete of channels.
I would first with the remote direct enter a channel like 03 enter to see if set has a problem or not.
Oct 21, 2012 | Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How do i add chanels
In the menu with auto program OR direct enter channels with the remote and in the menu manually add them one at a time(most sets have a add or delete feature in menu for single channels).
May 16, 2012 | Sampo SME-32DL5 32" TV
MANUAL FOR AKAI TV
Done with a remote by using "menu" button first and then in setup selecting auto-program to program all available channnels.
There should be also there in that menu a way to add or delete single channels.
Mar 21, 2012 | Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
I lost the remote control unit and i need to program the channels for catv. how can do it with the existing buttons ?
Most of the buttons on your remote should be on the TV too,at least the important ones.Look all around the edges for them,top,sides,bottom.To program the channels,press the menu button and search around for channel searching options,perhaps auto-search or antenna.If you auto search,you can get rid of channels you do not want(I dumped c-span and a couple others)by going to that channel after the search,press menu,and you will have to fish around a little because it slightly varies between brands,but eventually there will be an option to add/delete the channel.The channel button or volume button will allow you to add/delete.
Since you did not list your brand and model number,if you send it to me I could check out how much a new one is.I would guess at least $60 though. Good luck!
Jul 27, 2010 | Televison & Video
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Haier HLT71 7 in. Portable TV Logo
279 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
