Question about Refrigerators
Ffridge is too cold..nothin has changed..have attempted to adjust warmer but still too cold
  • 122 Answers
Control is stuck in the on position. some have a themostatically controlled damper to control airflow. If the damper doesn't close it can get too cold. check the damper for blockage. Sometimes ice will build up causing it to stay open.
Posted on Mar 21, 2011
When turning up or down does that number mean the current room temperature or what you want it to be? And when doing that is the lower number mean cooler or warmer? And the number being displayed at all...
The number you can adjust is the temperature you want. A lower number is colder and a warmer number is hotter. Remember that even if you turn it up or down by a lot, it doesn't change the temperature any faster. The number you cannot adjust is the temperature at the thermostat.
Oct 17, 2017 | Heating & Cooling
29502 freezer
No other way to make changes. Issue is more then likely the thermostat that needs to be changed. Basically it's thinking your freezer is warmer then it actually is
May 19, 2014 | Kenmore Freezers
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Lincoln navigator 03 hard to start when cold
Have you checked the fuel pressure with a gauge before and after the first attempt to start in the morning ?
Feb 18, 2013 | 2003 Lincoln Navigator
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
How do I adjust the cold control on my Amana refrigerator?
get a thermometer and adjust the control to the desired temperature
Nov 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator does not get cold enough 50 degrees.
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks.
Mar 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
