Question about Vizio VF550M 55 in. LCD HDTV
Tv turns on but there is a black screen, input menu etc does not show up on screen.
  • Vizio Master
  • 5,425 Answers
If you still have the audio, then it's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
(shopjimmy.com has the backlight inverters: http://www.shopjimmy.com/catalogsearch/result/?q=VF550M . Make sure to find your part number first.)
Posted on Mar 21, 2011
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have a 60" Samsung led TV. Model number UN60EH6003F/type UN60EH6003. The TV turns on but doesn't show a picture. You can see the screen light up but stays a black background. Which board is bad?
well 1st before id go changing any parts I look at weather or not the input is selected correctly over to the input that im providing a known good picture signal with (antenna,cablebox,etc.), you'd be surprised how many times I get a call and I go and use the input select buttons on set itself (NOT REMOTE) and whhoolaaaa! there it is , of course I always hear next I didn't change that !!
a short comings of todays modern TV's if you arnt having any signal into it ,the screen is black and the set-up menu wont display on a black screen
Oct 27, 2015 | Samsung Televison & Video
Television comes on for a second and then screen turns black but tv still on
Does the OSD (on screen display) come up when you hit the menu button? If so try changing the input to the one you need.
Apr 04, 2012 | Televison & Video
Rca tv... screen is black when you turn it on but it will show the Menu and let you go thru the menu... It also says tv is muted and wont let you turn the tv up
In the menu see if you change the input selection to something you know is on (a cable box, DVD player) and make sure that is the input picked.
Dec 25, 2010 | RCA Televison & Video
Issue with our Toshiba 50H82 - overnight it has stopped playing DVD's properly - a solid black rectangle obliterates 75% of the screen. Any idea?
Do you see same solid black box in all inputs or just in dvd picture?
If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings.
And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function.
Hope this will solve your TV problem.
Thanks.
Nov 29, 2009 | Toshiba 50H82 50" Rear Projection...
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
No Sound, Black Screen, 42" KDF-e42A10
If your tv is flashing 7 times. Disconect audio module. It is on top of power supply. Turn tv on you will have picture. Conect the audio outout from the rear. To the aux. input of a stereo. Where you night control audio level. Or get a new audio board. Its is very expensive get only the audio amp I. C. The audio. part. No. 1-866-539-11
May 25, 2009 | Sony KDF-E42A10 42 in. LCD Television
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Black Screen, but menu shows up
If you are sure that it is connected right and tested the audio inputs because to do that you will need an original remote, then you have a bad tuner or input switcher IC and no I am afraid that the TV most likly is not worth fixing. Good Luck
Mar 23, 2007 | Samsung TXN2745FP 27" TV
Vizio VF550M 55 in. LCD HDTV Logo
631 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
