Question about General Electric WCVH6800J Front Load Washer
I have a 12 month old GE wcvh6800 that when run on on normal will not go to rinse part of the cycle. Alot of pauses that you have to hit start to get going again. Using delicate cycle works fine. I did clean out pump filter, some soap scum but that was it. any suggestions?
In order for the pressure switch to work it has to get pressure.
The switch is located near the top of the right side panel and can be seen by removing the top cover. There is a small pressure hose that leads to the switch and should be checked for crackes or chafing. There are three round sponges on this hose to keep it from rubbing on the moving parts. I had to replace mine after just over a year so I used a heaver hose with the same inner diameter. I used a 3/16 fuel line from Pricess Auto and two new 3/8 stainless hose clamps.
Posted on May 31, 2011
First, check out http://www.fixya.com/support/t8312220-ge_wcvh6800jms to run a diagnostic. I'm having the same problem and it's apparently the pressure switch hose. My t06 test is showing an E.
Also see if http://forum.appliancepartspros.com/washer-repair/91162-ge-front-load-washer-wont-wash.html describes your problem. BE SURE to heed the warning about the cancel/drain near the end of the page - I just spent 2 hours cleaning up water.
Posted on Apr 09, 2011
  • Gatorflier Apr 20, 2011
    I had Sears come out to check it. The first tech said my problem was a $145 pressure switch, which had to be ordered. The 2nd tech came out a week later to install the part. I asked if he would instead install the pressure hose, then test the washer. The hose off the truck cost $16 - I ended up saving $130.
    A test he used was to remove the hose and use a syringe to blow air into it while crimping off one end. The air escaped through a nearly imperceptible hole, proving it was the hose.
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
General Electric WCVH6800J Front Load Washer Logo
214 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
