Question about Sennheiser Audio Players & Recorders
I bought a pair of Sennheiser HDR 140 wireless headset and I no longer can receive a signal from my amp. I had a friend whom has the same modle try them on his tv and they worked fine. I used them the night before and they worked great but te next evening when I picked them off the charger the headset would beep 5 times then shut down. I checked my connections and also the voltage of the batteries and all seemed ok. waz up??
  • 4,924 Answers
Probably ..they discharged to the max..and this way the connection was reset...If they are still functional ..you have to pair them again with the transmitter... and will work again ...If they work ..avoid in the future to discharge them totally ...
To pair they usually have a button that have to be pressed and will blink until picks up the signal ..or take a look in the manual to see the exact procedure for this model ..
Posted on Mar 21, 2011
I cannot control the volume on the headset...only on the TV. Any thoughts as to what I can do?
You could try taking out the batteries for a minute.
If that's no help then contact Sennheiser customer support:
Jul 23, 2016 | Sennheiser HDR 170 Wireless Headphones
Sennheiser Wireless Headphone picks up unwanted transmissions
This headset uses a 900 MHz frequency for connection from the headset to the base.
You will always incur lots of interference in a busy office using that frequency band. Any antennas on the roof or close by?
Amateur radio users?
The other thing, you might have a faulty power supply or "dirty power" coming into the unit. You can try and isolate in a current regulating power bar and see if that helps.
Else, consider changing technologies and moving to, say a DECT band.
Avoid, 2.4 and 5 GHz bands as they are in the wireless devices range and likely will incur equal amounts of interference.
Jan 08, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
How do i pair my headset with my blackberry curve
Here's a video walk through from Sennheiser on how to pair your headset to a bluetooth enable phone.
Mar 05, 2011 | Sennheiser VMX100 Bluetooth Headset...
I have lost my manual how do I pair my earpiece?
If you go to the following webaite:
http://www.sennheiser.com/comm/icm_eng.nsf/root/products_mobile_vmx100
Under the Download heading you will find a link for the Consumer Brochure. That is the user guide that you need to download for the steps to take to pair your headset and phone.
May 21, 2010 | Sennheiser VMX100 Bluetooth Headset...
Sennheiser VMX100 not working with G1
make sure you oreder your bloothoth from htc and its for the g1 next time
Jan 23, 2010 | Sennheiser VMX100 Bluetooth Headset...
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
388 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
