Question about Intertherm Heating & Cooling
I have a intertherm furnace modle M1MB 070A BW, and my problem is that it is not working it says that the pressure switch is open and i tried cleaning the filter and nothing, tried takein the swtch out the lupe by adding a wire lupe and it said it was fine but no fan kick in and the fan does work and so does the air conditioning so please help me!!!!!
3 Suggested Answers
  • 17446 Answers
SOURCE: What kind of filter does
IF the unit has a louvered front panel, the filter is attached to that. Take the front panel off and you should see it on the back of the panel. The size and specifications are on the filter.
See this diagram. IT has a manufacturers number for the filter but it wont tell the size:
http://www.batchelorsupply.com/Nordyne/Furnaces%20-%20HUD/M3%20parts%20list.pdf
Posted on Nov 28, 2010
  • 3 Answers
SOURCE: just replaced pressure switch on intertherm m1mb
CHECK FLUE FOR OBSTUCTIONS AS WELL AS COMBUSTION AIR INTAKE FIRST. THEN CHECK TO SEE IF THE FURNACE DRAIN IS OPEN AND NOT CLOGGED [ONLY IF YOUR FURNACE IS A CONDENSATING HIGH EFFICIENCY MODEL, typically the flue pipe will be 2 or 3 inch pvc pipe] over the years more often than not, it is an obstruction or poor drainage which will not prove the pressure switch to allow the burner to ignite. in rare cases the furnace control board could be bad as well.TRY DISCONNECTING FLUE AND COMB. AIR AT FURNACE JUST TO SEE IF FURNACE WILL IGNITE. HOPE THIS HELPS!!!!!!
Posted on Dec 12, 2011
My furnace has stopped it is a intertherm propane furnace. It says pressure switch is open
Blow down the tubes on the pressure switch you should hear it click . Take the tubs off the pressure switch clean the connection inside with a small drill bit this may get it working again if not possible new pressure switch . Also check flame sensor is clean .
Mar 15, 2018 | Intertherm Heating & Cooling
My nordyne m1 mb 056a bw heater isnt working...a red light flashes twice, which means "Pressure switch is open"...how do i fix it?
First, I am assuming that this is a residential gas fired furnace. 1. The first thing that will happen once the furnace gets a call for heat is the small draft inducer motor will come on. 2. The pressure switch should close. If the switch is not closing, here is a list of possible reasons: 1. The draft inducer motor is not running. 2. There is a restriction in the flue or heat exchanger. 3. The tubing from the pressure switch is not connected or has a leak. 4. The pressure switch may be defective or stuck open. Note: this is not an exhaustive list, but should cover the most common causes. Also, you may have to unplug the furnace and then plug it back in before it will try to come on. It may be locked out on the control board because of the pressure switch fault. I hope this helps!
Nov 30, 2015 | Heating & Cooling
Intertherm M3rl080A BW furnace that shuts down will no indication of fault
If your diagnostic indicator is not picking showing a fault code than it thinks everything is ok with the furnace. It could be a bad thermostat. (or the heat anticipator in the thermostat).
Jan 30, 2014 | Intertherm 56000 Btu Gas Furnace
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Just replaced pressure switch on intertherm m1mb gas furnace but still codes "pressure switch open"
Oct 20, 2011 | Intertherm P3RA-048K Air Conditioner
I got a intertherm furnac 7yr old and the ignition control box flashis 3 times when i turn the heat on. i know there is gas ,so its eather a false flame or a failed ignition attempt..what can i do to...
First clean the flame sencer and retry or jump out the pressure switch and see if it lights check rubber hoses to pressure switch are not split , check air filter is clean
Sep 15, 2011 | Heating & Cooling
I have a Honeywell furnace model #M1MB 070A BW. How do I replace the igniter?
Hello, first turn off power to the Furnace, then remove igniter from bracket and unplug molex connector. Then take the igniter to a Hvac supply store and get new one, reinstall it into bracket plug into molex connector and turn furnace back on.
Mar 05, 2011 | Honeywell Heating & Cooling
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
Furnace has does not ignite flame
how often do you replace your filter?
On the limit switch that protects your unit when it gets to hot the number one reason is dirty filter.
The pressure switch is located in the upper side of cabinet has a rubber hose connected to it. They very rarely go out though. So find your vent fan the first fan that comes on and follow the rubber hose to the switch.
Feb 09, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
527 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
