I have a KENMORE 110 24422300 Washer it just died not working at all I checked there is a power on the socket but washer is not working at all can you advise me what could be the reason?
danromarris
  • 101 Answers
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Posted on Jan 23, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I remove the top of a Kenmore 110-24422300
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
If you have questions,, please let me know. I hope this helps you.
Posted on Jun 28, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore 70 series washer 110 22702100
3.2 cu Ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer has smoke smell, now won't turn on
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 25, 2010
Series 90 Kenmore washer will not turn on.
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Mar 31, 2013 | Washing Machines
My front load kenmore HE2t wont start. It has power, no kinks in the hoses. No error message is flashing.
see this causes and fix it. God bless you
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Sep 30, 2012 | Kenmore Washing Machines
You: Model #11047532601 Kenmore Residential washer doesn't turn on wath could be the cause???
see the following steps: use the common sense God bless you see the diagram.
2. Lid switch
Aug 01, 2012 | Kenmore Elite 45986 Front Load Washer
There seems to be no power to my washer while all the other appliances in the same room are fine. The fuse box is OK. Is there a reset button on the washer itself?
hi.
first thing to do is plug the washer into a different socket.
if the washer still does not work, then there should be a fuse, either in the plug, or inside the machine itself.
if the washer works in a different socket, then there is a problem with the socket itself which should be dealt with by a qualified electrician, as a fault socke or wiring in the wall can be a serious fire risk.
if you are in any doubt, consult a qualified electrician.
hope this helps
Jul 12, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore Tumble Action Front Loaders power will not turn on. It worked fine yesterday but now there is no power what could it be?
Hi from retired Englishman in SW France @ 167:37 Sat afternoon!
You need to check the socket it is plugged into first. Try another device- maybe a kettle- to see if there is power. If not then a trip/fuse has gone on your main supply panel.
If there is power at the socket the fuse in the plug (if there is a fuse) needs checking and ,if necessary, replacing.
Come back to me on email john.cross@aliceadsl.fr if neither of the above solutions identify the fault.
John C
Jan 29, 2011 | Kenmore 44102 Front Load Washer
KENMORE MODEL 110 WASHER WONT DO ANYTHING, JUST DEAD
you need to make sure you have power comeing out of your wall socket first. then let me know. also is any of your lights on your display lite up?????? control lock?????
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
2. Lid switch
If all the above checks out OK, replace the touch pad.
May 30, 2009 | Kenmore 2205x Top Load Washer
No Power will not switch on at all
no lights at all? take top off. check power present at suppressor capacitor (1st in line to power inlet) and power present at output from suppressor. you will needs a meter. check on/off switch has power at input and output
Apr 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Kenmore 43142 Front Load Washer
Have you switched the power on? you could try a radio or something in the socket. Have you turned on the water valves? Tom.
Feb 28, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
