Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Hp officejet pro l7780
After changing ink cartridges, wont print blue or red colors, please advise
  • 5 more comments
  • RjeanT Aug 04, 2008
    We installed new ink cartridges blue & Magenta. They have not expired. The printer will not print in color. it does show that all inks are full. I have cleaned the print heads, re aligned the printer and no correction has been made. I have also looked in the manual and there are no troubleshooting answers for this. Please help.
  • jayozz Sep 05, 2008
    I have the same problem I have cleaned the print head several times. I don't see a cleaning tool on the menu as suggested. I also get horizontal lines equaly spaced but not every time.
  • Michael Colby Jan 27, 2009
    i have run the cleaning tool till the cows came home. Red prints brown and blue is closer to purple than blue
  • coins00 Feb 10, 2009
    cant print in black ,i replace the ink bus still have the same problem
  • diane1953 Mar 16, 2009
    I have HO Officejet Pro L7780 and have changed all ink cartridges.
    It shows all levels 'full' but it will not print red or blue... Anyone have any ideas howto fix this??
  • RjeanT May 11, 2010
    Thank you for trying but I have already done this.
  • Anonymous Mar 12, 2014
    after changing ink cartridges
    Scholar:
  • 67 Answers
Run the cleaning tool before you print a test page.
Posted on Aug 02, 2008
HP7780 not printing any color
Go into printer properties and check to make sure you don't have "black ink only" selected. If that's not the case, use your printer tools to see the estimated ink level for your color cartridge. If not low, try removing the cartridge and and dabbing a wet paper towel over the bottom of the cartridge to see if any ink comes out. Sometimes this will get the ink moving again. Otherwise, replace the color cartridge.
Sep 07, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 has stopped printing in black after changing yellow cartridge. Black is barely showing in spots. Have cleaned the heads and restarted twice and black cartridge is almost new, at...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Won't recognize black cartridge on hp officejet pro l7780
Ok what you need to do is powerdown the printer the pull all ink out of the printer power it on without in then power it down again and replace the cartridges. If this doesnt work go into the control panels and select the color of the ink as only B&W and print a test page
Oct 18, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
Aug 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to change ink cartridges Pro L7780 All-in-one
Do you mean the ink cartridges or the printheads...
If it's the printheads see this solution:
http://www.fixya.com/support/t1407056-printer_print_in_black
It it's the cartridges you just open the little door (left/front of the printer), remove the cartridge which is flashing red and then put a new one in the same way.
Jan 29, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
478 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
