Question about ASUS Eee 4G Notebook
The computer will not turn on at all when plugged in
    Novelist:
  • 107 Answers
Try doing a hard reset by removing all peripherals connected to the notebook and the battery. Once everything is disconnected, press and hold the power button for around 15 seconds. Put the battery back then try to power the PC on. If still same issue occurs, check the light indicators. There should be an LED that tells if the battery is charging, if you don't see any, try using a different AC adapter. If still the same issue exists check your PC's manufacturer there could be a possible hardware related issue.
Posted on Mar 21, 2011
How to get my keyboard back working on my desk top
1: if the keyboard has a round plug going into the computer, it is a PS/2 plug. Turn off your computer, unplug the keyboard, then plug it back in, making sure it is plugged into the correct place for the keyboard (and not the mouse). Then turn the computer back on.
2: If the keyboard has a USB plug, it is not necessary to turn off the computer first, just unplug the USB cable for a few seconds then plug the cable back into the computer. If it still doesn't work, try plugging the USB plug into another USB port on the same computer.
3: If neither option works, you may have a defective keyboard.
Sep 05, 2017 | Top Computers & Internet
Computer won't turn on after trying to plug in
You never plug anything into the expansion slot whilr the computer is turned on and running. This is a sure way of damaging the motherboard.
Turn off the computer and remove the wireless adapter and then boot up your computer, if it still does not boot up then the motherboard most likely been damaged.
I suggest you take it to a computer repair shop to assess the damage and give you a repair quote.
Jan 03, 2013 | Computers & Internet
Sony Cybershot DSC-W180 won't turn on when plugged into computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Sony Cybershot DSC-W180 10.1MP Digital...
It is stuck in power saver mode tried every thing can not get in come back up. Tried turning off and on, unpluged and pluged back in, put in cd, tried starting in safe mode with F8 key.
Possible that it's caused by a faulty hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. Reseat the CPU and start the computer.
Jan 09, 2010 | Acer Aspire AM5641-U5520A PC Desktop
Plugged it into my computer, now wont even turn on!
HI,
TURN IT ON WHILE ITS CHARGING WITH COMPUTER,SOME TIME THERE WILL BE STROKING ON PROLEM..
TNKS
RABBANEES
Nov 04, 2009 | Pure Digital Flip Video Ultra Camcorder
The power switch does not switch (no click)
Unplug the monitor from the power
Unplug the monitor from the computer
Plug the monitor back in.
Try turning it on.
DOES IT SAY "NO SOUCRE DETECTED" or soemthing like that???
if it DOESN'T it means there is something wrong with the computer.
if it DOES:
plug it back on to the computer, turn the computer power off.
Press and hold the power button on the computer for about 15 seconds.
Plug the computer back on.
Try turning the computer on.
if it's not turning on again there a problem either with your monitor cable, or the plug, or the video card plug. It is unlikely that your video card is broken if you hear no wired series of short and long beeps when you try turning the computer on.
Good luck.
Give us updates if you need more assistance
Aug 11, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Camera won't turn on when plugged in to computer
After you connect your camera to your computer, you have to turn on the camera manually. It will not come on automatically. Good luck!!!!!!!!!!!!!!!!!!!!!!
Jun 16, 2009 | Kodak Easyshare C813 Digital Camera
I want to put some music on my zune, but it will not register as being plugged in or turn on.
I let it sit overnight and plugged it into my computer, while my computer was plugged in, and it turned on.
May 01, 2009 | Audio Players & Recorders
Turns the computer off when plug USB into a computer
did you try using the camera with a different data cable? there could be a peoblem with the data cable you are using
Aug 16, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
ASUS Eee 4G Notebook Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
