Cell Phones Logo
Posted on Mar 21, 2011
When Connecting the mobile videocon v 1424 to the sysytem using USB port system showing Driver failed. not showing the Mobile Information. sandeep tiwari
3 Related Answers
Anonymous
  • Posted on May 30, 2009
SOURCE: i need samsung pc suite for connecting inter net to my sysytem through my mobile
you need to buy it
Anonymous
  • 1118 Answers
  • Posted on Sep 21, 2010
SOURCE: my mobile PUK CODE IS
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Anonymous
  • Posted on Feb 01, 2011
SOURCE: hi, I am receiving DNS
hi, I am receiving DNS failed in my CORBY GT-S3653 mobile while i m trying to connect internet (i m using AIRCEL network)..... pls provide me solution to solve this issue...
How can I use my Nokia E72 Mobile as WebCam connecting with my PC with USB port or Bluetooth?
1helpful
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
1helpful
2answers
MY MOBILE IS NOT CONNECTING TO P C ALLTHO PC
its not only pc suite that needs to be installed. You also need to install nokia connectivity driver. This willl install your usb cable.
You can download the connectivity driver from the nokia link below.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-6102i/pc-software/cable-drivers
Also cross-check if your usb cable is well connected to your phone and computer.
Take care.
1helpful
MY IBM COMPUTER SHOWS A WINDOW SAYING IT DOES NOT RECOGNIZE THE HARDWARE, WHEN AN ATTEMPT IS MADE TO DOWNLOAD PHOTOS FROM MY MOTOROLA CELL PHONE.WITH USB CONNECTION.
Motorola Mobile Phone USB Drivers (for Windows®) This USB Driver is used for connecting your Motorola Mobile Phone to a Windows® computer via a USB cable in order to charge your phone or to access the data on your phone.
Supported Handsets This USB Driver supports most Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile® and Motorola i-mode Handsets.
System Requirements
  • A 32-bit or 64-bit version of Windows 2000®, Windows XP®, or Windows Vista® Operating system.
  • You must have Administrator permission to install this driver.
Notes
  • Please reboot the system after installing the USB Driver.
  • Installation of Motorola Phone Tools may affect the performance of this driver. Please re-install the USB Driver after the installation of Motorola Phone Tools.
* MotoConnect is a PC application that keeps your Motorola device drivers up-to-date. Additionally, on supported phones, MotoConnect can launch the owner support page for your phone giving you easy access to user guides, FAQs, tutorials, videos and more.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
12helpful
4answers
Require Spice d-88 gold modem driver and software
I have a spice d 88 gold (cdma + gsm) handset. I downloaded its modem driver from spice website but the zip file is corrupted. Please provide me the modem driver and software for Spice d88 Gold handset
Jul 17, 2009 • Cell Phones
2helpful
Usb mobile device
go to this site.http://www.samsung.com/us/support/download/supportDownMain.do
select your phone and download usb drivers for your operation system, install and it will detect
1helpful
IPhone can't charge and can't be detected by PC
Be sure that your Windows PC meets the minimum system requirements to use iTunes and iPhone. This is particularly important if you are connecting iPhone to your computer for the first time. iPhone requires a specific minimum version of iTunes.
Ensure the computer's drivers are up to date
iPhone requires USB 2.0 to function properly. Refer to the documentation for your computer to verify that the USB ports are high-power USB 2.0 ports. Try connecting iPhone to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPhone to your keyboard's USB ports is not recommended.
In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
iPhone requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPhone the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service. If these are not installed, see the Reinstall iTunes section below.
Verify that the driver is installed by connecting iPhone to the computer and following these steps:
  1. On the Start menu, click Run.
  2. In the Open field, type devmgmt.msc and click OK. A list of devices will be displayed.
  3. Scroll down to Universal Serial Bus controllers and click the small plus sign to expand this group. iPhone will be listed as either Apple iPhone or Apple Mobile Device depending on the version of the driver installed.
  4. Right-click Apple iPhone (or Apple Mobile Device) and choose Properties from the shortcut menu.
  5. When the Properties window opens, select the Driver tab.
  6. Click Driver Details to view more information.
Verify that the Apple Mobile Device Service is installed and running using the Services MMC snap-in using these steps:
  2. In the Open field, type services.msc and click OK. A list of devices will be displayed.
  3. View the list In alphabetical order and verify that the "Apple Mobile Device Service" status is "Started."
    1. If the status does not indicate the service is started, right-click Apple Mobile Device Service and choose Startfrom the shortcut menu.
    2. If the service is installed and started, right-click the service and choose Restart from the shortcut menu.
    3. If the driver is installed and the service is installed and started, check the Event Viewer for error messages.
      2. In the Open field, type eventvwr.msc and click OK.
Jan 24, 2009 • Cell Phones
3answers
Nokia N72 USB port
you need drivers for your nokia install on your PC. Check any CD if you got one or browse www.nokia.com
1helpful
4answers
PC SYNC OF PHONEBOOK
I CAN NOT SHARE DATA TO MY PC FROM MY LG MOBILE PHONE RD8000 RELIANCE.I PLUGED USB PORT IN MY PC,
THE PC ASK ME INSTALL SOFTWARE CD,WHEN I PURCHASE MOBILE THERE IS NO CD ONLY DATA CABLE,I GOT.
KINDLY GUIDE ME. &REPLY ME
PGOWRISHANKAR,
CHENNAI.
[email protected]
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
