Control Switch diagrams for CA20.A441-603.E - Heating & Cooling
Call for service CA20 how to fix Model Toshiba e-studio2006 ?
Recommended only if you have technical expertise or call for a tech.
Code
CA20
Description
Laser optical unit related service call. H-Sync detection error: H-Sync detection PC board cannot detect laser beams.
Causes
MAIN board Laser optical unit
Remedy
1 Are the harness open circuited and the connectors disconnected between the MAIN board (CN33) and the laser optical unit? Yes 1. Even if the connector is not apparently disconnected, it may be connected loosely. Therefore check carefully that it is secure. No 1. Replace the MAIN board. 2. Replace the laser optical unit
Dec 04, 2017 | Toshiba Computers & Internet
Hi I need cylinder head bolts torque settings for Nissan skyline ca20
??Just Google your request above "head bolt torque settings Nissan skyline ca20" Lots of info available. Google
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 11, 2016 | Nissan Cars & Trucks
I have got problem with copier toshiba e-2830 error code CA20
try rest the copier by switch on the copier while pressing '0&8"
enter 690 press start button enter 2 press enter key on touch screen, wait till you see 'Reboot the machine: It is communication err.
May 09, 2014 | Toshiba E-Studio 3511 Color Copier
Head bolt torque engine CA20 nissan
Head bolts Nissan skyline ca20
Sep 02, 2013 | Cars & Trucks
Error code ca20
toshiba estudio 232 errr ca20 wt problems?
May 25, 2013 | Toshiba e-Studio 232 Black and White...
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511 CA20
CA20 indicates H-Sync detection error . U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201) on the LDR board open circuited, broken or disconnected.
Sep 25, 2009 | Toshiba E-Studio 3511 Color Copier
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
