When I either refill or use a non-oem or remanufactured hp 74xl cartridge in my c4480 it will not indicate ink levels. Is there any way to get the printer to see the ink levels with a non-OEM cartridge?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
There is no way at no oem but cost less
check here how can you refill them easy
with out any tools
http://www.youtube.com/watch?v=MPi2GqJg5QM
Posted on Mar 23, 2011
Ink reset HP J6410
Unfortunately, you cannot reset the HP 74-75 ink cartridge ink level monitoring feature once they are empty (either refilled, remanufactured or compatible ink cartridges)...however print operations are still permitted. Watch this 'Low Ink Warning video' for all printer models which use the HP 74-75 ink cartridges:
HP 74, 75, 74XL, 75XL Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
Diagnostic Tap 41 Test (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
NOTE: To access the diagnostics menu on the HP Officejet J5700 or J6400 series printers, select * and # keys simultaneously and enter 124 (or 123). From there you can access the Reports Menu, 'print-mech tap test and run the diagnostic code=41 test (see video above for reference) - this will tell you the exact health of your ink cartridges. To run it I think you'll need to access via '124' access code for the HP OJ J64xx printer series.
For more information, please visit:
www.inkjet411.com
Feb 20, 2013 | HP Office Equipment & Supplies
HOW CAN I RESET INK CARTIDGE LEVELS ON HP DESKJET 3510
When you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this 'low ink' phenomena.
Additionally, severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Feb 18, 2013 | HP PhotoSmart C4480 All-in-One Printer ...
Ink refill costco hp printer C4780
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena, the 2nd video provides suggested cartridge prep/handling instructions when you return the cartridge for refilling:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
If the new (or refilled/reman/compatible) HP 74, 75, 74XL, or 75XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. If you run into a problem where the ink cartridge is performing marginally and blocks printing (via the Red X), you can bypass the error message (usually only 1 time per clearing action):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. You can also run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test).....go to www.inkjet411.com for more information on your specific printer model.
Feb 16, 2013 | HP Photosmart C4580 All-in-One InkJet...
How to reset hp 901 ink
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered by Costco and Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels CANNOT be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty - it uses fusible links so the electronics are literally blown - thus non-reversible).....so you just need to live with the low ink messages and ignore ink low, non-genuine, counterfeit, fraud messages and similar while you are using these types of refilled or aftermarket ink supplies.
Refer to Inkjet411.com sitelet for all printer models which use refilled ink cartridges (most major brands and models) - see videos below on HP 901 and 901XL low ink warning messages, along with all the other more severe error messages:
http://inkjet411.retailinkjet.com/
Jul 24, 2012 | HP OfficeJet J4580 All-In-One Laser...
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Reset a hp 74xl printe cartridge
If this is OEM ink and not Genuine INK then you got to play it by ear. WARNING refilled ink does damage the print head in this unit and can cause undisired effects. If you have been using refilled ink for a while then your damage is already in its begining stages. But the indicator on these cannot be reset to estimate the ink because it does nto have a chip resetter in it. Thanks
Aug 03, 2010 | Canon MX310 Office All-In-One Printer
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
158 people viewed this question
k24674
jasbo
jasbo
