Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Controller got wet and now the speed lights flash on and off
  • 692 Answers
Controller getting wet does not help Sorry but you will have to replace the controller
Posted on Mar 21, 2011
Cruise control on 2000 ford explorer change the pressure switch on master cylinder and it still does not go on
The pressure switch on the master cylinder has nothing to do with the cruise control . The pressure switch as you call it is not a pressure switch at all . Brake fluid level sensor . The brake switch is under the dash on top of the brake pedal linkage (arm) .
Speed Control The vehicle speed control consists of the following components:
  • speed control servo (9C735)
  • speed control actuator cable (9A825)
  • speed control indicator lamp
  • speed control actuator switches (9D743)
  • brake pedal position (BPP) switch (13480)
  • deactivator switch
  • anti-lock brake control module (2C018)
  • clutch pedal position (CPP) switch
  • Self-Test Diagnostics
    WARNING: This test is a key on engine off (KOEO) test only that is conducted in PARK only with parking brake fully engaged.
    • Enter Self-Test Diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator lamp on the instrument panel will flash once to indicate that the speed control module entered the diagnostic mode.
    NOTE: Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
    • Release the OFF switch.
    • NOTE: If the ON switch is not pressed within five seconds after entering the diagnostic mode, the module times out and the procedure must be started over.
      Press the remaining switches in this sequence: ON, RSM (resume), CST (coast), and SET/ACCEL. The speed control indicator lamp will flash as each switch is pressed. Press each switch in the sequence immediately after the light goes out for the previous switch.
    • A lamp flash with the last button (SET/ACCEL) indicates that the STATIC test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective. If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
      • Two flashes - Brake pedal position (BPP) switch is defective, circuit is defective, or brake pedal is applied; clutch pedal position (CPP) switch is defective, circuit is defective, or clutch pedal is applied.
      • Three flashes - Brake deactivation switch is open or circuit is defective.
      • Four flashes - Vehicle speed signal is out of range or circuit is defective.
    • Immediately after the static test has passed, the speed servo will then carry out a dynamic test automatically by actuating the throttle lever from 1mm to 10 mm of travel from the idle position. During the dynamic throttle pull, observe the throttle movement to witness any binding or sticking of actuator cable, correct connection of actuator cable to throttle lever, and make sure the throttle returns back to idle position. If incorrect connection and/or binding or sticking of actuator is observed, go to the Symptom Chart. If dynamic pull at the throttle body is observed, Go To Pinpoint Test A .
    • Return the ignition switch to the OFF position and proceed to the Symptom Chart.
    Symptom Chart
Symptom Chart
NOTE: Self-Test Diagnostics must be carried out before proceeding to the Symptom Chart.
Symptom Chart Condition Possible Sources Action
  • Flash code 1 - system pass
  • System Pass.
  • Flash code 1 - no dynamic pull at throttle body
  • Speed control actuator cable.
  • Speed control servo.
  • GO to Pinpoint Test A .
  • Flash code 1 - speed control inoperative
  • Circuitry.
  • GO to Pinpoint Test D .
  • Flash code 2 - BBP switch circuit failure
  • Circuitry.
  • BPP switch.
  • CPP switch or jumper.
  • GO to Pinpoint Test B .
  • Flash code 3 - deactivator switch
  • CJB Fuse 13 (20A).
  • Circuitry.
  • Deactivator switch.
  • GO to Pinpoint Test C .
  • Flash code 4 - speed signal circuit failure
  • Circuitry.
  • Anti-lock brake control module.
  • Flash code 5
  • INSTALL a new speed control servo. REFER to Actuator - Speed Control Servo . TEST the system for normal operation.
  • The speed control is inoperative - no flash codes
  • CJB Fuse 10 (7.5A).
  • Circuitry.
  • BPP switch.
  • Speed control actuator switches (9D743).
  • GO to Pinpoint Test E .
  • The speed control does not disengage when the clutch is applied
  • BPP switch.
  • CPP switch (M/T).
  • Circuitry.
  • GO to Pinpoint Test F .
  • The speed control switch is inoperative - COAST
  • Speed control actuator switch.
  • GO to Pinpoint Test G .
  • The speed control switch is inoperative - SET/ACCEL
  • Speed control actuator switches.
  • GO to Pinpoint Test H .
  • The speed control switch is inoperative - RESUME
  • GO to Pinpoint Test J .
  • The speed control switch is inoperative - OFF
  • GO to Pinpoint Test K .
  • The speed control indicator lamp is always on
  • Circuitry.
  • Instrument cluster.
  • GO to Pinpoint Test L .
  • The speed control indicator is inoperative
  • Circuitry.
  • Bulb.
  • REFER to Section 413-01 .
  • The set speed fluctuates
  • Circuitry.
  • GO to Pinpoint Test M .
  • Engine (6007).
  • REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. REPAIR engine as necessary.
Jul 04, 2018 | Ford Cars & Trucks
Meaning damp
Hi Ron, I would take the bike to your local dealer or reputable bike shop, they have the expertise on local and geographic weather conditions that may be unique to electrical issues on your bike. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2014 | 2007 Harley Davidson FLHT Electra Glide...
I am noticing a flashing light on my dashboard. The item flashing is a car with lines coming from behind the car. it is beside d seat belt icon. What does it mean, and how can I fix it?
the symbol with a car and 2 curved lines behind means:
"Slip control" or "Stability control" (also known as ESC, ESP, ASR or DTC) warning.
Toyota Trac Inop Light Toyota's traction control helps you maintain traction on wet, icey, loose or uneven surfaces. There are complex wheel speed sensors that will trigger the traction control safety feature as needed. If you see the trac inop light illuminate, this feature might be disabled. A Toyota service rep can access the trouble code and identify what is needed to fix any potential issues. - See more at: http://jeffwylerclarksvilletoyota.com/section/secondary/toyota-dashboard-indicators#.dpuf
Toyota Dashboard Indicators
Jan 15, 2011 | 2003 Toyota Camry Solara
Which fuse is for cruise control in 2003 ford f150
The fuses for the speed control from the factory are :
Engine Compartment fuse panel #7,
Cab fuse panel Fuses #15, #13, #5
The fuse that goes to the recall part is Fuse #13, 20A
The recall is 05S28. Description: Speed Control Deactivation Switch.
The part number for the recall is : 1L1Z-9F924-AA
The part has a fuse inline that is marked as non serviceable, but 1 revision I saw, it was just an ATM fuse under tape. Not sure if this is the final revision that was used on your truck ( or should have been used ).
The self test for the Cruise Control ( for 00-03 MY, with the CC light on the cluster ) :
With the key off depress and hold the cruise control off button while turning the ignition to the run position,don't start the truck, the cruise light will flash once to let you know it is in self test.
Five additional flashes indicate a bad cruise control servo
Release the cruise off switch and within 5 seconds depress the other switches in sequence:
1. on
2. resume
3. coast
4. set/ accel
The speed control light will flash as each switch is depressed.
If the last one does not flash it may then flash a code
After this the cruise will move the throttle to test the actuator and the cable.
Make sure the throttle returns to idle and turn the key off.
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
- 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
- 3 flashes - deactivator switch is open or circuit defective.
- 4 flashes - vehicle speed signal is out of range or circuit is defective
4. Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
5. Return the ignition switch to the OFF position and proceed to the Symptom Chart.
Oct 19, 2010 | 2003 Ford F150 Regular Cab
Cruise control no working on 2001 f-150 4 x 4 5.4
Did you have the recall done ?
recall 05S28. Description: Speed Control Deactivation Switch.
Try the self test for the Cruise Control :
1. on
2. resume
3. coast
4. set/ accel
WARNING:
Note:
Oct 15, 2010 | 2001 Ford F150 Styleside SuperCrew
The traction control lite and arrow on the dash and shifter keep blinking it doesnt make a difference what button you push
The first thing to do is have the computer scanned for codes, theres a problem maybe a speed sensor but scanning will help in finding the problem,
Jul 10, 2010 | 1996 Volvo 960
Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Jun 06, 2010 | Golden Technologies Companion II Travel...
S flashing on the dash of a 1990 honda accord, automatic transmission but it wont move very well in drive 4, it needs a new automatic transmission control until can i still drive it until I can afford to...
On my 1990 Accord Lx I have the same problem.  My floor pan has a hole in it some where and my carpet gets wet which gets my computer wet causeing the "S" light to flash and then when my tranny shifts it skips 2nd gear.
Mar 29, 2010 | 1990 Honda Accord
Blender now only has one speed and it's overspeed. Is there an overspeed govenor that causes the blender to automatically shut off? It will overspeed about 3 seconds before it stops working and all the...
there is a voltage regulator inside the circuit board , this might have got wet some how . this circuit controls 1-10 speed from a touch of a button . will have to disassemble unit , Auth personal should check this , unless you know electronics
Mar 19, 2010 | KitchenAid KSB3 Classic Work Top Blender
The check engine lights comes on and my cruise
Did you have the recall 05S28, Speed Control Deactivation Switch done ? If not, get this done ASAP. If so, could be the inline fuse in the recall harness is blown. Check for leaking brake fluid on the switch, at the end of the brake booster.
You can try the cruise control self test, to see if the CC is functioning.
WARNING:
Note:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
— 3 flashes - deactivator switch is open or circuit defective.
— 4 flashes - vehicle speed signal is out of range or circuit is defective
Feb 12, 2010 | 2003 Ford F150 Regular Cab
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
104 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
