Question about Refrigerators
PLEASE Only Answer this question if you know this model I am an Appliance technician. Whirlpool S21S4d side by side fridge freezer. Serial#=110507015236. This unit alarmed and warmed up I found the evaprator in the freezer frosted so it wasn't Defrosting, the Defrost element tested ok, I've changed the freezer temp sensor, the Defrost thermostat and the Main rear pcb. The unit went fine for a couple of weeks and is now back to not Defrosting and has the same temp alarm beeping and flashing. The freezer display now only shows "--". Please help!!!!!
  • alwaysprompt Mar 21, 2011
    Cheers Macmarkus, I believe there's a factory fault with this models computers but I can't find any info, I hope someone knows if one of the front PCB's could cause this issue.
  • alwaysprompt Apr 27, 2011
    It wasn't the heater. In the end the fault couldn't be proven but I still suspect a factory issue with the PCB's. We had to write this unit off.
  • Refrigerators Master
  • 19,396 Answers
Hi.
I cannot track the model through the serial. I think we are talking about an Australian model here.
If the evaporator coils were frozen, then it is likely a defrost problem, full-stop. I could invent about electronic faults, but the side by side defrost system is still controlled through the timer, electronic boards will unlikely give as only symptom a frozen evap, while the fridge keeps functioning.
Disconnect power cord and perform full defrost. If the fridge does not restart cooling, even after manually defrosting, then the problem is likely electronic. Concerning either damper system (if present- do not forget I have not tracked the number), or it is electronic. A defective compressor is unlikely the problem because it won't have cooled at all, and the evap. coils won't have frozen.
If you find out that the fridge is working after manual defrost, then check only the parts concerned when there are defrost system problems.
Check if the fridge has double evaporator. Some new side by side have two evaporator coils that work together, one behind freezer firewall and one behind fridge. If there is dual evaporator for fridge and freezer there are two elements and thermostats to check. In that case there is also a three way valve between the two evaporators that must be tested.
If the evaporator is OK, check the main control board at the base of the unit. That board hosts relays that distribute power. Check components and replace it only if the problem is not evaporator itself (test and double test), and if you see something wrong in there (eg. bulged capacitor, clicking relay when on, resistor not showing continuity).
I cannot be more specific without schematics. See if there is a service tag with a model number inside the fridge.
Posted on Mar 21, 2011
  • 2,605 Answers
Welcome to FixYa.
I'll just throw this out there and you can take it for what it is, just my experience as a fellow technician.
I've seen some recent defrost elements being broken which 9 times out of 10 check out OK. It is usually right at the point of where the wire enters the element and it has fooled me at first a few times. I can ohm it out and it seems fine. I got lucky one time and as I was twisting the wire checking continuity, it showed itself open, now I've seen several over the past 2years or so.
I have been repairing appliances for around 20yrs. and it is something I've only seen occur recently on late model fridges. I will admit most of those have been of the Frigidaire/Electrolux variety, but I just thought I'd put that out there for you. I know you could be scratching your head over this for days otherwise and it may not be the case, but you may want to try a heating element...considering all you've done this far it would appear you have nothing to lose.
Here's wishing you luck from one who's been where you are. Good luck.
Regards,
Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 21, 2011
    Hey thanks, cheers to you too. I do alot of Whirlpool warranty work so I will check into it with the folks I know here and let you know what ( if anything ) I find. Good luck in the mean time.
    Regards,
    Macmarkus :)
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
How do I know if the freon needs to be replaced on my whirlpool freezer
You will need to replace the "bi-metal thermostat" in the freezer. Here is the part to order. It also has a video to show you how to make the repair.
Oct 31, 2012 | Whirlpool Refrigerators
My s21s4d fridge ice maker doesnt work, everything else is ok. the motor on the ice m/c doesnt seem to reset itself. how do i fix it.
Hi and welcome to FixYa, I am Kelly.
This appears to be a Whirlpool side by side unit. Commercial Code 858618353010 / Model S21S4D. If I got the brand incorrect please respond with your brand name.
I do not know your geographic location. I am assuming you are outside of the US.
There are a couple of troubleshooting links I will post here. Keep in mind that they are for US units but the only difference will be the operating voltage:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34 This is for the BASIC ice maker without optics.
And Job Aid R-92 (With optics)
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note there are 2 different optics for these. Pre and post 2002. You will have to determine which one you have. The troubleshooting steps require that you TAPE the door / light switch in the depressed position. Ensure you read all of the set up steps.
Often ice makers stop cycling because the ice maker thermostat never reaches 14 - 16 Deg. F due to a problem with automatic defrosting. Ice builds up on the evaporator coils and air-flow in the freezer gets restricted. It will still freeze but won't make ice until the ice build up is excessive.
If you think you may have an automatic defrosting problem do a MANUAL defrost with an external fan by turning the unit off, removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. (water mess so be ready)
While the fan is melting the ice in the freezer compartment... open the lower rear of the unit by removing the fiberboard cover and cleaning the condenser coils, condenser fan, the drip pan and the ver end of the compartment drain tube that terminates in the drip pan. Reinstall rear cover when complete.
After the 2 hours clean up the mess and return the unit to normal service. The unit should start making ice within 8 hours. It will operate normally for 2 days and then if the automatic defrost problem exists... ICEMAKER and freezer performance will degrade after 2 - 3 days.
Hopefully you have enough information now to troubleshoot your icemaker issue.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Refrigerators
My refrigerator is not cool, but the freezer works fine.
Sounds like a defrost problem.
It is a defrost problem since the ice that freezes on the freezer coils
is not being melted by the defrost system.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check evaporator fan in freezer If this was helpful please rate me
Thanks for using fixya
IMUFO2
Leo Ponder
imufo2@sbcglobal.net"
Jul 20, 2011 | Whirlpool GS5SHAXN Side by Side...
I have water dripping from the hole at the top of the fridge where the doedorisor is stored. What is the problem?
Lets try to see if your defrost drain is blocked. Unplug power and remove contents of freezer section and then remove rear panel in back of freezer to expose evaporator coil. Not every refrigerator is the same but the movie below will help you get the idea better of what to do. Once you find model number click on the Whirlpool Logo and there you will find most appliance user manuals along with parts manuals so you can see a better view of your refrigerator=>
sea_breeze_6.jpgNow Click Here=>
And if you have trouble please let me know, sea_breeze_7.jpg I am a Whirlpool Service Technician and by clicking on the refrigerator Model number locator you will be able to Contact Me through my web site or here, Thanks, Sea Breeze
Dec 05, 2010 | Whirlpool Refrigerators
Whirlpool S21S4D Ice maker stopped working Now fridge stopped working Frezer OK Defrosted ice on condenser and fridge working for time being! Do you think its the mother board?
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Feb 04, 2010 | Refrigerators
No cold coming to fridge or freezer
I woud say your heater has malfunctioned and it has frozen your fridge, you will need to remove the inside plastic wall on your freezer side if its side by side and get a blow dryer and melt all the ice if this is the case. You would need to change the heating element which defrosts your freezer/fridge everyday to prevent freezing up. You can get this heating element from an appliance store where all the appliance repair people get them specific to your model. Its less than a hundred bucks.
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
