Question about Dell Dimension 3000 PC Desktop
On board video...
I just bought a new video card for my dell dimension 3000, i am ready to put it in but i don't know how to disable the old video adapter. it is built in to the mother board. please tell me how to do this. i greatly appreciate it.
  • 38 Answers
If it doesnt, take the old card out again and when you first start the PC press the f10 button. This will bring you into the BIOS and you can look around and change it to look at the new card first.
Posted on Aug 20, 2008
    Master:
  • 397 Answers
The BIOS will most likely be set to auto detect, when you physically install the new card the BIOS should detect it and auto disable the onboard video.
Posted on Aug 02, 2008
Replaced video card in Dell Dimension 3000 with NVIDIA GeForce FX 5500. Can't find video controller driver
Hi.
Click on the link below and download the driver for the card, if you are unsure then click on the Supported Products tab and you will see that the FX 5500 card is supported in the download.
http://www.nvidia.com/object/winxp_175.19_whql.html
Regards.
Feb 04, 2013 | Dell Dimension 3000 PC Desktop
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Apr 18, 2011 | Dell Dimension 2400 PC Desktop
Pc powers up but no video on screen gateway 420gr desktop
Yes generally speaking when you drop in a videocard it typically will disable the built on one. You may have to disable it though. I know you said you did not see the onboard video in BIOS but there is almost always a setting in there to turn it off.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
I need a new processor and motherboard for a dell dimension 3000
By the time you spend all that money you could have bought you a new Intel 2.8Ghz dual core processor with 4GB of RAM..keep the one you have for stuff you want to experiment with and buy yourself a new computer
Mar 10, 2009 | Dell Dimension 3000 PC Desktop
No display
In the BIOS, it would be under on board peripherals/devices if it's there at all. On board AGP or something...
If there's no BIOS setting to disable on board video, it should recognize the new card.
This may sound silly but is the card completely seated in the slot? Sometimes it may seem like it is. Something to check anyway...?
Mar 06, 2009 | Dell Dimension 2400 PC Desktop
Video card not working, monitor goes off
     In the bios there could be setting to disable your onboard video. Since the output was broken, see if there is an option to disable the onboard setting. If you do this and you are still having problems, I would go ahead and start in safe mode, then lower your resulution to the lowest settings till you can get the video drivers loaded for the new card that you have just bought.
        Joe < Data Miner >
Oct 31, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Open MY Dell Dimention 3000
ok
look..the graphic card is a miniature board,witha radiator on it,and it is situated perpendicular on to the mainboard.you will see that from its behind there a wire which goes directly to the monitor.thats the recognise part.
in case your computer has no video card,just onboard graphic adapter you have to identify the AGP or the PCIE slot from your mainboard.
this is how you do
look on the mainboard..youll see the processor un the middle..big,with a fan on it(ventilator)
under it..there are some long slots..like 10,12 cm long..paralles between them and paralles with the lowest laturaof your computer case..
the fisrt from up...the one which is situated upper is the agp one
I exclude the possibility to be a PCIE slot because your computer is not a today one..you more than sure you have a AGP slot.
ussualy is a brown or red collor..anyway it is different by th eother slots paralel with it.
ok..you put there the video card and voila...youre done.
however if you had no video before just the integrated on mother board solution,go in bios and desactivate the onboard video.
after that,put the instalation cd or just the ati catalist driver for your new nice agp ati radeon 9600 video board.
with all done,you should have a new board:)
like an advice..I dont recomand you to do this alone..go to a specialised service and let them do it for you,ask them to let you see the job for a next time...but now..if you never did that ..its quite ok to let a specialist hanndle it.,ok?
good luck
oh by the way..you may surf for a while on internet to see some photos with video boards atached on mainboards..
i give you the link whwere I found your dell..It might not have a video board,but only a integrated video on mother board..
so
http://reviews.cnet.com/desktops/dell-dimension-3000-celeron/4507-3118_7-31077378.html
good luck
inform me later how it went,ok?bye
Feb 06, 2008 | Dell Dimension 3000 PC Desktop
CARDS FOR Dell Dimension 3000 PC Desktop
Dimension 3000 accepts only regular PCI cards according to the Dell site.
Dec 24, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
193 people viewed this question
Alun Cox
