Question about Konica Minolta DiMAGE Z6 Digital Camera
I have the timer set for 10 sec, how do I make it work?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Konica Minolta Master
  • 102,366 Answers
Once you have the self-timer set, start it by pressing the shutter release button as usual. The camera will focus, meter the exposure, then delay for ten seconds before firing the shutter.
Posted on Mar 21, 2011
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
I installed a Woods 59720 timer switch to control a small bathroom fan. First time I turned it on 5min cycle it worked fine. Now, it runs only 10-15 seconds, then turns off. Set for maximum 30 minutes, it...
I looked it up and it sounds like your unit is defective. It should run for 5, 10, 15, or 30 minutes. There are no "seconds" options. The timer chip/module may be defective.
Gary
Sep 04, 2011 | Woods 59720 Automatic Wall Switch Timer...
How do u use the rc6 for instint photos not two second. What do you set on the camera. 5D mark ll
don't set for 2 sec, set the camera to 10 sec self timer and click the remote, should work instantly with every click. just remember to set for regular shooting if not using the remote. can be very annoying to wait 10 sec for a shot, unless you want to be in one?
Jul 04, 2011 | Canon RC6 Wireless Remote RC 6
I have an Olympus Camedia C-5050, and i have read that it does have a self timer feature on it, i would just like to know how i set the self timer? thanks
Check the menu under settings. Look for an icon that looks like a tiny clock. There are typically two settings - 2 sec and 10 sec.
Jan 12, 2011 | Olympus Cameras
My Sony digital still camera F707 works very quick self timer (cca.2 sec.) May I readjust for original 10 seconds? Thanx for help!
There is no setting to change self timer, default time is 10 seconds. However you can reset camera to restore default settings by pressing reset button located under battery compartment, try it as it might correct self timer problem.
Thanks.
Jan 05, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
I can't figure out how to set the timer
with my cybershot i have to hit the timer button and select how many seconds, 2 sec or 10 sec and then hit the capture button ( the button you use to snap a picture)It beeps when its been set and then does a countdown. Y'all can try that?!
Oct 14, 2008 | Cameras
SELF TIMER Z760
Here's how it works.
Press the Menu button. (Some settings are unavailable in some modes.)
Press 'up arrow' or 'down arrow' to get to the 'Self Timer' option which looks like moz-screenshot.jpga clock set at 10 minutes to 10.
Press the OK button.
Press the Menu button to exit the menu.
(This setting will stay until you take a picture or turn the mode dial).
Good Luck
Mar 26, 2008 | Kodak EasyShare Z760 Digital Camera
Timer on samsung digital camera?
Sure ... be sure to use a tripod or other device to place the camera for stability.
  • Set the MODE DIAL to your desired photo setting
  • Press the SELF-TIMER button on the button pad (looks like a clock/timer on the right button pad)
  • There are three settings
    • 10 SEC - 10 seconds will pass until the picture is taken
    • 2 SEC - 2 seconds until the picture is taken
    • Double self-timer - a picture will be taken after 10 seconds, and then after 2 seconds a second picture will be taken.
  • Press the SHUTTER button to begin the timer.
  • Jump in the shot! =)
Please rate FixYa! ThankYa!
Dec 15, 2007 | Cameras
Konica Minolta DiMAGE Z6 Digital Camera Logo
154 people viewed this question
Top Konica Minolta Cameras Experts
ktpierce
Level 1 Expert
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
