Question about Linksys Wireless-G Broadband Router
I need the WEP number and can't find it. i will also take the WPA key as well. serial number on my router is CGN70F190345. MAC address is 0016B61033f8.
    Novelist:
  • 107 Answers
Unfortunately the serial number and mac address can't really help us here. You would have to change the password yourself on the router if you don't know it, or reset the router. Both of these things can be done by using a computer that is wired into the router (via an ethernet cable) and entering in 192.168.1.1 into the Address portion of your web browser.
The user name will be blank, and the password by default is 'admin'
Hope this helps
Posted on Mar 21, 2011
    Sergeant:
    Champion:
  • 234 Answers
WEP and WPA are security measures setup by the end user. Please consult web or printed documentation on resetting router to factory defults.
How do i watch i-player through my wii? got wireless connection,but got error code 51330 hope you can help,thanks!
The error code 51330 on Wii usually indicates that there is a problem relating to wireless security. You can try the following steps below as it should solve the problem:
If you are using WEP or WPA security on your router try this:
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
But if your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
1. go to our Wireless Router look up page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Lastly, Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
I hope the above solves your problem.
Good luck.
Oct 23, 2010 | Nintendo Video Game Consoles & Games
Tip
How to solve wireless/internet connection problems on Wii Consoles
You can try the following steps below as it should solve wireless/internet connection problems on your Wii console :
1. Log into the router using the default IP (consult your router's manual for assistance).
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
Good luck.
on Oct 23, 2010 | Video Game Consoles & Games
My wii is not signing on line error code 51331 is a it says please help
Hello xklown777
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
Log into the router using the default IP (if you don´t know this, consult your router's manual for assistance). Locate the "wireless security" section of your router settings and find the WEP or WPA key.
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
3. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
The above steps usually resolve the problem. If the error message still comes up, there are other ways I can help you, but it would help if you could tell me the model number of your router, as some models have compatability problems with the Wii.
Hope this helps.
ajblaj
Sep 17, 2010 | Nintendo Video Game Consoles & Games
I am trying to connect to internet the screen says erro code 51330
Hello val171156
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
Hope this helps.
ajblaj
Sep 14, 2010 | Nintendo Wii Console
What is error code 51331?
Normal.dotm 0 0 1 253 1446 Statens bygningstekniske etat 12 2 1775 12.0 0 false 21 18 pkt 18 pkt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} Hello rb_singer
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
Hope this helps.
ajblaj
Sep 13, 2010 | Nintendo Wii Console
Error code 51330
This error is faced by many other users too. There is a procedure you have to follow to solve this error.With this procedure some gets solved and some does not. In that case the Nintendo support center needs to be contacted for reset internally.
The procedure is as follows:--read it carefully and completely and then follow it properly.
Error Code: 51330
WPA - PSK (TKIP).
WPA - PSK (AES).
WPA2 - PSK (AES).
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
Click here to go to our Wireless Router lookup page.
Sep 01, 2010 | Nintendo Video Game Consoles & Games
Error code 51332 unable to connet to internet
Error Code: 51332 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Jul 01, 2010 | Nintendo Wii Console
I need a wep code for an Actiontec GT704-WG. Trying to setup internet connection for wii and the code that is on on the modem does not work .
here is a setup guide to help you get the wep key. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
May 15, 2010 | Actiontec GT704WG Wireless Router...
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
