Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
When I press the bake button it doesn't turn on the oven and the temperature display has faded out and is no longer visible.
  • 122 Answers
Most likely your control module/board has failed. You cold be looking at a relay board, which is usually on the back side of the oven, and a control module. cold be a 400-500 dollar repair. still cheaper than a new range.
Posted on Mar 21, 2011
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The teamperature on the digital display can say 350 degrees and the oven thermatore that is located in the oven reads 310. Does this oven need to be calibrated? The oven is 6 years old.
The thermometer that hang on rack are Whooly inaccurate. A good one is the TAYLOR brand. As long as things bake within recipe time no adjustment needed but to do it;
  1. Press BAKE
  2. Select the maximum temp. depending on model it either 500 or 550
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
But before doing that i suggest a new high quality thermometer that you hang on oven rack
Aug 12, 2011 | Ovens
How do you recalibrate the oven temperature of a Whirlpool Accubake oven system
To do that;
  1. Press BAKE
  2. Select a temperature of 550 or highest temp on some models its 500
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
Gene
Aug 12, 2011 | Whirlpool Ovens
Frigidaire range model #fgfl67dcf needs to be calabrated, too hot for setting
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Jun 18, 2009 | Kitchen Ranges
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
162 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
